Go Back   Boat Design Forums > Design > Propulsion > Surface Drives
Old 11-06-2004, 06:31 AM
zingaroo zingaroo is offline
Rep: 10 Posts: 4
single surface drive?
In an attempt to reduce weight to the stern of my 28ft sports cruiser and also reduce the maintainance costs, is the use of a single prop surface drive an option in place of the heavy mercruiserTRS11 outdrive unit?
I am repowering with a GM 6.5 single V8 diesel (thanks Carteret) and would like to explore the drive options, I presume "prop walk" would be a problem?
also whilst on the subject I have two SS matched contra-rotating cleaver props, I am told they are designed for "semi-surface" piercing use? what is the feeling on this?
Have a good day all,
Zingaroo.
:confused:
Old 11-29-2004, 05:53 PM
D'ARTOIS D'ARTOIS is offline
Rep: 311 Posts: 1,069
Zingaroo<
I have some experience with SDS (surface drive systems), be ikt with larger vessels and as soon as I hear the "cost-saving" topic, I start to tremble.
First of all, a surface drive system, even for a single prop, needs pretty good calculation of the required propellor dimension and speed. A surface piercing propellor is way from the usual one that is much less complicated. You cannot just attach a random SDS prop on your driveshaft. Furthermore, you may still require reduction- and fore-aft gears so the weight of your geartbox still must be added. In the end your total weightsaving might only some kilo's.
Old 12-31-2004, 03:34 PM
mk1 zingaro mk1 zingaro is offline
Fletcher Zingaro
hi strange to find someone doing the same thing as myself I also have a fletcher zingaro currently fitted with a 300hp motor;diesel max rpm 3800 running a conventional shaft system spinning 18+19.5 cupped equpoise getting 32 knots / was very disapointed Thinking of trying SDS as well not sure though ps, let me know how your getting on, need for speed is a disease i think.
Old 01-03-2005, 06:38 PM
champ champ is offline
Rep: 10 Posts: 2
the fishingboat won
the fishingboat won ha ha ha ha
Old 01-06-2005, 02:10 AM
tom kane's Avatar
tom kane tom kane is offline
Rep: 265 Posts: 865
I see you are getting the good info.
tomkane
Old 01-06-2005, 09:03 AM
CaptPPan CaptPPan is offline
Rep: 10 Posts: 45
Hi,
I have a single gas eng (330 hp) in my 27' center consol with a single fixed surface drive and it works very well. There are some pictures on the "Shaft through the transome" post. I've found that a much larger then expected extremly "Cupped" prop works best, so a gear reduction will be necessary.
CaptPPan
27' Harley "SeaVenture"
Trimmable surface drive system? Robbi Surface Drives 6 10-08-2011 04:35 PM
Surface Drive Discussion Burns Boat Design 10 06-12-2006 03:47 AM
Gimme Power !! Willallison Option One 38 05-26-2006 07:53 PM
iges trimmed surface problem in maxsurf hasicktear Software 16 02-13-2006 12:25 PM
surface and subsurface drive all in one tom kane Press Releases 5 11-08-2003 04:58 PM
