| shallow water, outboard surface porpelle. Hello everyone. I'm Gian, Italy. I want build a Shallow Water Boat and I designed what is in attachment. Is a boat in meters, long 5.5, wide 1.7, and 0.8 high. The rivers have absolutely no waves, are slow, with gravel. The boat, fully loaded weighs 650 Kg and fishing 0.1 meters, has to consume little and do not need to run. I would like to apply outboard (height adjustment with piston air). What can I bow? According to the tunnel you can make the effect of the demos that are here? http://www.flatscat.com/performance1.htm Ciao a tutti! |
I like it--what engine will you use? |
| For this I asked you opinion...in My opinion a Mercury 40/60 may be ok. Some idea about the bow mount? |
| For this I asked you opinion...in My opinion a Mercury 40/60 may be ok. Some idea about the surface propeller to mount? |
| That design will make the boat draw more (sink deeper). A flat bottom boat will have less draft.
__________________ Gonzo |
| Tunnel hulls Yor concept is valid, and proven by ultra shallow running flats fishing boats in the States. The tunnel may make the boat draw a little more water at rest but will allow you to run shallower. Take a look here: http://www.fishnetdailynews.com/Arch...TunnelHull.htm and other places using search terms: flats boats tunnel hull If you don't need to plane than a there is no getting around a flat bottom as drawing the least amount of water. Steve Quote:
| Sure, Gonzo. But with a flat boat I can't install a jet. If a propeller (in or outboard engine) is installed, it must be under the keel. Or not? TU Gian |
| My question is: the propeller, positioned at the end of tunnel, can be higher than the keel? |
| If you install a jet, a flat bottom is a requirement. At least on the aft end.
| Design aluminium shallow water | Gian Milan | Jet Drives | 67 | 04-07-2012 07:34 PM |
| Shallow Water Tunnel Design | YK GEO | Propulsion | 22 | 11-11-2009 05:31 AM |
| Depth sounder for shallow water | tom28571 | OnBoard Electronics & Controls | 18 | 01-16-2008 07:32 PM |
| Shallow water RAO | wbouwmans | Boat Design | 0 | 10-11-2006 02:11 AM |
| Shallow water propulsion | john zimmerlee | Propulsion | 9 | 06-29-2006 06:23 PM |
