Go Back   Boat Design Forums > Design > Propulsion > Surface Drives
Old 01-15-2010, 02:33 PM
dand0_4 dand0_4 is offline
Rep: 10 Posts: 21
Shaft seal
I know this has probably been addressed, but I couldnt find much about it. I am building a flat bottom aluminum boat with a trimmable surface drive, but I am not sure what to use for a shaft seal. Since the shaft will move up and down and mostly be above water level, I want to use the right part. The transom is 90degr. and the shaft will be running straight out the back to a cutlass bearing. It is a 1" shaft with a chevy 350 for power. Thanks
Old 01-29-2010, 04:13 PM
fishon91's Avatar
fishon91 fishon91 is offline
Rep: 10 Posts: 43
mcmaster carr will have what you need.
any type of oil seal will work, but of course there are different ones for different applications. find one that suits your needs.
im not sure what to tell ya cuase im not sure how youre designing it.
if i was doing it, i'd put the shaft inside a housing, exactly like a car axle. there will be just a little bit of rotating shaft at the end of the tube, behind the prop.
Old 01-29-2010, 05:24 PM
Rep: 1493 Posts: 7,447
If it is out of the water, it will probably need to be lubricated and cooled with water. A dripless would work well
Old 01-29-2010, 06:29 PM
CaptBill's Avatar
CaptBill CaptBill is offline
CaptBill
Rep: 64 Posts: 181
How about a high tech solution.
Make a ferrofluid bearing. No friction, no contacting parts, no wear, waterproof seal, no heat either. Plus this stuff has great dampening characteristics. Got access to a milling machine? They look simple enough to DIY.
I think what you might need would be a pivot joint like here
http://machinedesign.com/article/the...-bearings-1103
Gotta see this.....
http://www.youtube.com/watch?v=ULSG3pkjoT4
Old 01-30-2010, 10:54 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,256
That would be the 1st ferrofluid bearing around a 1" shaft that runs at just a few thousand rpm.
I agree it looks simple, but that goes for a lot of things.
Old 02-05-2010, 07:10 PM
CaptBill's Avatar
CaptBill
Rep: 64 Posts: 181
How about a ferrofluid chainplate deck opening/mounting. Imagine being able to pass a coin from the cabin to the outer deck. Could you MAKE water come below? Might be tricky. May not enen be possible. Dont know but shure would like to know.
Old 02-26-2010, 03:25 PM
fishon91's Avatar
Rep: 10 Posts: 43
the shaft is coming out the transom, right? i see a lotta mudboats with the shaft comin out the bottom, not a true SD. i dont see the point in all the watercooled/ferrofluid design. whats wrong with keepin it simple and doing grease seals, bronze bushings, and marine grade grease? a pressure lunricator thing like godevil uses are pretty nice too. harder to find, just drill and weld nut to housing to install
i would definitely like to see more of your project cause i have plans to build a mudboat later in life, and i'm nosey..... ; )
Old 02-27-2010, 05:26 AM
Poluting the waterways and breaking the Law
Old 02-27-2010, 09:18 PM
fishon91's Avatar
Rep: 10 Posts: 43
illegal?? i've never heard that before.... thats how all the longtails and surface drive are done here in the south, actually all over the U .S. by mud motor companies.
i don't mean to sound like a J.A. know it all, but this isn't soundin realistic to me.
Prop shaft tube, bearings and seal design pdwiley Metal Boat Building 25 12-23-2009 09:22 PM
Transom seal bigcford Sterndrives 9 07-05-2009 11:58 PM
is it a short shaft or long shaft? donell67 Outboards 2 03-13-2007 11:07 PM
long shaft or short shaft Bill Kubiak Powerboats 17 05-26-2006 12:00 PM
short shaft motor on long shaft boat ohenry Boat Design 0 03-21-2005 08:02 PM
