Go Back   Boat Design Forums > Design > Propulsion > Surface Drives
Old 04-07-2011, 11:29 PM
JPT JPT is offline
Rep: 10 Posts: 2
pivotal drive subsurface or surface all in one
Looking for information on Cam.A Propulsion pivotal drive or something similar that would be easy to manufacture and low cost.Possible to power with twenty horsepower honda or equivelent. Needs to be trimmable for shallow rivers. any information would be appreciated .
Old 04-12-2011, 04:56 PM
tom kane's Avatar
tom kane tom kane is offline
Rep: 287 Posts: 887
Cam.a.Propulsion the first Practical Trimmable Shaft Drive for powerboats.
Inventor Tom Kane. Conceived 1950`s.Patented New Zealand 1973.The logical way to easily install a shaft drive in a powerboat keeping in mind that a fixed drive will be more easily damaged and be inconvenient to trailer and launch your boat.
Go to www.shareaproject.com search Pivotal Drive or search Boatdesign web site.
pivotal drive subsurface or surface all in one-step-aboard-_-safe-fuel-system.png  pivotal drive subsurface or surface all in one-advantages-cama-resized-.jpg
tomkane
Old 04-13-2011, 09:54 AM
JPT JPT is offline
Rep: 10 Posts: 2
Hi Tom and thankyou for your reply. I really like like this idea of yours. I am new to inboard designs like this but would like to build something similar for my plywood boat. Do you run a surface piercing prop? If so, compared to other surface drives is the distance from transom to prop a concern.
Old 04-13-2011, 04:44 PM
tom kane's Avatar
Rep: 287 Posts: 887
Surface propulsion is best for very fast boating taking as much advantage from reduced drag as possible and all you want running in the water is just the prop and shaft and rear strut.
If you look at fast race boats the prop is relatively close to the transom as are many other surface propulsion drives.
The position of the prop depends most on size and design of the prop.
There are many ways to build a trimmable shaft drive but a trimable drive using the same components as a conventional fixed shaft drive should be easy for any engineer (or non engineer) and if so designed you could use it for surface or sub-surface propulsion.
pivotal drive subsurface or surface all in one-tunnel-s_p-mode.jpg  pivotal drive subsurface or surface all in one-aeropowered-hydro.jpg
tomkane
First Surface Drive ? MickeyFIN Surface Drives 10 12-22-2009 12:57 AM
Stern shape design for surface drive/stern drive Alik Boat Design 8 06-15-2006 07:36 PM
Surface Drive Discussion Burns Boat Design 10 06-12-2006 02:47 AM
surface and subsurface drive all in one tom kane Press Releases 5 11-08-2003 03:58 PM
