Go Back   Boat Design Forums > Design > Propulsion > Surface Drives
Old 05-16-2010, 04:52 PM
jeffejo jeffejo is offline
need help with inboard mud boat
i have a 15' 52 boat that is prety sturdy with a subaru motor that puts out around 85 hp. It has a drive that resembles a surface drive i cant get this thing to plane out with more than 2 people and it has a hard time with just 2. If im in the boat by myself it will jump right up and knock you down if you arent careful. Any suggestions on how to get this thing to plane out.
Old 05-17-2010, 01:09 AM
baeckmo baeckmo is offline
Hydrodynamics
Rep: 962 Posts: 631
First: FACTS! What components do you have in the driveline? Reduction gear? Propeller type, blade numbers, diameter, pitch? Is it submerged or surface piercing? Boat shape, weight, center of mass position? Engine power characteristic, max power at what rpm, engine rpm's when not planing?
PICTURE of prop arrangement pls!
Old 06-04-2010, 09:53 AM
mudman mudman is offline
Rep: 72 Posts: 88
Subaru's dont realy make the HP until ypou hit higher RPM. What engine do you have the EA71, or the E81, EA 82. I built one a while back that had a mud unit on it. Is this the same super go devil style unit?
If so, I needed trim tabs. Be sure that the engine is trimmed down on take off to pop the back up. Then trim up until it rooster tails. Then trim back down until you are throwing a 1 to 2 foot tail.
If it's prop, call Benji at New Iberia Propeller as he builds the units.
mud boat plans for the experts fishon91 Boat Design 21 01-12-2010 06:51 PM
Prop Size For Homemade Mud Motor muddin redneck Props 0 12-16-2009 07:21 PM
Help Needed-Want to bild a mud motor prop simplebobby86 Props 2 10-21-2009 10:38 AM
Mud Motor Drawing mudman DIY Marinizing 3 08-01-2009 08:33 PM
Mud Motor Mark Emaus Inboards 16 06-09-2009 05:10 PM
