| Having raced both V-bottoms and tunnels, and doing my own prop work, I can tell you that you cannot replace cup by larger diameter, the result would be a much lower top speed. There's a sudden transition to higher speeds that occurs with raceboats/surfacing props that's not understood. Quote:
| PS When the outfit is set up with a surfacing prop the cup certainly does not kill low speed performance. An uncupped prop will run very inefficiently at all planning speeds, low and high. |
We at Flexitab feel that surface propulsion is perfectly suitable for low speed vessels, this is why we tested a ship (clearly not the one mentioned by others in this thread) in the naples tank test, were surface props outperformed well-tuned submerged ones. (see pictures attached in the "Surface propeller and low speed displacement boat " thread). Regards, Brunello |
Cup increases bow lift. Contrary to theory, which is pretty piecemeal, we do not run sq rt 2 more diameter with surfacing props in racing, we run the same diameter or less. I've wondered (naive question): for top speed with light load, is thrust the right parameter to maximize? I'm not sure. Thanks for the post! Last edited by sandhammaren05 : 01-21-2010 at 02:54 AM. Reason: spelling error |
| Yes, go to WWW.simplicity-marine.com they have been using there surface drives for tow boats and parasail boat for years. Alan |
| Monohull verses Multihull powersailers / motorsailers | brian eiland | Motorsailers | 258 | 05-15-2012 03:30 PM |
| Hull speed | Mike D | Boat Design | 33 | 02-27-2011 01:20 AM |
| bigger props faster ship? | Peter H | Boatbuilding | 23 | 02-01-2010 12:08 PM |
| Propeller Speed Theory | batboat | Props | 9 | 05-23-2009 06:29 PM |
| Full Displacement of semi | tdamico | Boat Design | 51 | 02-18-2004 09:42 AM |
