Go Back   Boat Design Forums > Design > Propulsion > Surface Drives
Old 01-23-2008, 07:46 PM
Steve H Steve H is offline
Rep: 309 Posts: 204
Thanks for the reply! Those are excellant numbers. I'm sure if you disassembled those drives you would find the part numbers you needed right on the bearings and seals. I would be very surprised if there were any parts in there that were only available thru the drive manufacturer.
Steve
Old 06-03-2008, 02:10 PM
ChrisN67 ChrisN67 is offline
Rep: 47 Posts: 49
Help ID a surface Drive
Steve I openned the drives up and they we in bad shape. They had been worked on by third country nationals who though it was ok to knock in bearings and used form-a-gasket like they owned stock in the company. I did get most all the bearings (timken made in france but I upgraded to german FAG) with the exception of a needle beering. My problem is with spares on hard parts like the rudder clevis which had been damaged.
I have understood that it was an arneson knock off and the manufacturer does not want to have anything to do with it less he gets sued.
Old 06-03-2008, 03:12 PM
Rep: 309 Posts: 204
After looking a little more closely at your pictures I think that the socket housings are Arnesons. It looks like someone just made some custom thrust tubes for them. Have you talked to Rik at Arneson Industries? He is by far the most knowledgable person you will find when it comes to surface drives.
Most opinions you will find on this board are tainted by an unknown childish agenda when it comes to anything related to Arnesons. So if you are looking for an informed opinion I would call Rik. He is very helpful and knows his stuff!
Steve
Old 10-02-2008, 06:51 PM
weehenry weehenry is offline
Rep: 10 Posts: 45
what type of prop is that on that single drive
Old 11-18-2008, 08:02 PM
brunello brunello is offline
Rep: 72 Posts: 21
I have a similar system on my boat and have been going nuts trying to find out the manufacturer. Common elements are:
Only vertical trim
Rudder behind prop
Rudder brace on superstructure connected soley to shaft housing
Oil feeder line to thrust bearing
Although there is not anything apparently wrong, I want to rebuild these units (at least seals;bearings if necessary) as they are over 6 years old. Please advise if you get a line on these drives. I have a post with pictures
Chris, most probably SBM, but surely not Victory Design. The logo "Victory" cast on the rams is not linked to a design of mine, but to a race team in Turin, owned by the man - I believe - behind this occasional SBM's venture into SD. If so, all seals and bearings should be pretty straightforward metric stuff.
Old 12-23-2008, 07:54 AM
fleetwing's Avatar
fleetwing fleetwing is offline
sea salt
Rep: 36 Posts: 21
After looking around and checkin they were assembled as a bastard system, to match the transmission, the drives were made by france helices www.francehelices.fr ,
Old 12-28-2008, 03:03 AM
Rep: 47 Posts: 49
SBM marine is looking like the best bet right now. Even though they deny it....I cannot find anyone else that comes close... I was hoping someone out there has seen a similar system.
I chased down the above statement prior to Xmas with following results:
Dear Sir,
Thank you for request.
Pictures that you send are not our surface drives.
You can see our production of surface drives SDS directly by the link http://www.francehelices.fr/surface-drive-system-uk.htm
If you need more information or quotation, do not hesitate to contact us.
We wish you a merry xmas.
Kind regards.
EMMANUELLE BEZZI
PUBLIC RELATIONS MANAGER
FRANCE HELICES
ZI La Frayère 06150 Cannes La Bocca
efficiency of surface drives and surface piercing propellers David Knight Powerboats 7 09-24-2009 04:10 PM
BPM trimmable, non-steerable surface drives? Jeff Powerboats 16 06-12-2006 04:51 PM
What makes a boat plane? pc245 Boat Design 20 12-20-2004 02:40 AM
who makes center consoles? Guest Boatbuilding 2 06-26-2003 04:39 PM
What makes a passagemaker Inerested Powerboats 1 03-22-2003 02:45 PM
