| Drive option Hello, I have a project Im working on and need ideas. I picked up a 20' (previous military) aluminum sled. Its very stout and no corrosion in this hull. Working on removing the camo paint. The yellow is aluminum oxide primer and is tough stuff! It had been modified with a Berkeley/Olds 455 jet setup. The motor was bad and on a pallet. It has no leaks in any of the rivets. (Filled with rain water before I pulled the pump.) The stern is 26" tall and straight up and down (needs 14*). Too tall for OB except jet pump version. But that would take a 200hp OB jet unit. Big $$$$$$ Yesterday, I saw a boat being built on this forum. I could modify mine similar to that one. Cut my transom down like this one, cover drop down ( swim platform/kicker bracket too) and replace cutoff transom material forward of the platform across the top. Battery storage etc under. Another option I like is keeping it inboard as a tunnel or Levi type system. I read threads until 2 am this morning and like this option best I think. This link to Levi has the info and is what I have in mind. http://www.levidrives.com/index.php/...n-25-foot-boat Their test boat is a bit heavier, but close enough for comparisons. The small diesel is great too. Opinions? Thanks for looking, Chris Last edited by crowsridge : 11-27-2011 at 05:33 PM. Reason: added picture |
| A bracket would be quite easy to install and you can adjust it to whatever height is ideal.
__________________ Gonzo |
| Hi Gonzo, That is very true. A couple points on that I have to deal with. In fact, I picked up a bracket for that purpose. But. There are a ton of rivets across the back. Many are flush, but many (50 or so) are round and some are 3/4" dia. They happen to fall right where the bracket goes too. I still need to fab over the holes and reinforce the transom to carry the load and deal with the rivet issue. To run in our shallow rivers, I would still have to buy the 200 with a jet. The 115 merc I have now wouldnt push it with a pump. Thats why Im asking about the tunnel and Levi. Thanks, Chris |
| A plywood spacing pad with notches drilled at the rivets would solve the problem. How bad is the pump? A used inboard engine to fit it would not be so expensive.
| The pump was like brand new. But I got soooo much flack over the "old inefficient pumps" I took it out and sold both units I had. The 455 Olds is toast and a monster. I have a 100 hp diesel, but its too small for the Brekeley. But its twice the size of the Levi unit in the test link I posted. Seems like a decent option. I suppose I could do the plywood option. Encapsulate it in epoxy. But I still have to fab over the holes and then buy the big o.b. and jet pump. The 14* mount for the pump would be just right for the Levi type.Then seal the intake hole. I could use one, or I suppose both of the exhaust ports and deal with those holes that way.??? |
| You can rivet aluminum plate over the holes. They make blind pop rivets.
| Before you do anything else, find out if that's a strontium chromate primer. If you can't find out- treat it as if it is. You can download MSDS and procedures from the web. |
| Thanks. I had already checked into that. Fortunatly, the liquid stripper takes off the top coats perfectly and leaves the primer untouched. No sanding will be needed this way. Inside is getting Line-X and paint outside. Im even contemplating vinyl wrap for the outside and not painting at all. |
| What is vinyl wrap?
| Most of the aluminum boats with color sides are vinyl now. If you see vehicles running around that appear to be wrapped in an ad etc? Thats vinyl. Small nicks can be regenerated with a heat gun. So says the shop anyway. Ive seen all kinds of designs. You could make it look like you drove through a flag and its waving in the wind or ad for your buddies business. Endless really. |
| That sounds like a good idea. Do you need to prime first? I wonder if salt water would corrode the metal under the vinyl.
| All the big fish boat builders are using it now from what the boat dealers and also the graphics shop I went to. I wouldnt think it would get behind it. If it tears, its exposing in just that space. A lot of businesses here wrap their vehicles in them. I guess its the same way theyre putting graphics on police cars now too. The graphics guy said theres no limit to what he can create. If you get tired of it, it will cone off. |
| I like it
| Back to the tunnel or Levi. I had an old boat guy by one day. He said to move things further forwaed in this boat. Thats okay for my wish too. sittimg on engine cover behind center console works for me. Which would perform better? A tunnel in place of the existing hole or Levi type equipment? |
| Moving the machinery forward may make the boat bow heavy. It may plow and oversteer. Also, it may end up broaching downwind.
| old option one updated | tom28571 | Option One | 0 | 09-25-2008 08:35 AM |
| new (old) option! | Starfish | Wooden Boat Building and Restoration | 13 | 03-17-2008 09:15 PM |
| Steering Option | barthautala | Boat Design | 28 | 07-20-2007 05:02 PM |
| Option One - how big | Willallison | Option One | 43 | 12-20-2005 05:44 AM |
| More Option One | duluthboats | Option One | 36 | 05-11-2002 08:46 AM |
