Go Back   Boat Design Forums > Design > Propulsion > Surface Drives
Old 07-10-2009, 02:57 PM
aziziyeng aziziyeng is offline
Rep: 10 Posts: 5
CFD codes for surface piercing propellers
I need some information about CFD codes for surface piercing propellers. Can you help me?
Old 07-10-2009, 04:20 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
Welcome aboard
And, yeouch! CFD of a surface-piercing prop.... just thinking about it makes my head spin.
I have no idea how to do such a complicated model; indeed, I suspect there are only a handful of people who do. Two-phase flow is enough of a pain as it is, without adding turbomachinery and a dynamically changing grid to the situation.
Now, if you're looking to specify a surface prop, as opposed to doing an actual CFD simulation of the flow patterns surrounding one, there are established benchmarks for doing that....
Old 11-10-2009, 09:22 AM
ubik ubik is offline
here is a paper on CFD simulation on surface piercing propellers
http://www.caponnetto-hueber.com/Pap...NUTTS_2003.pdf
Old 01-15-2010, 05:39 PM
brunello brunello is offline
Rep: 72 Posts: 21
Flexitab, in Italy, has been conducting an in depth research work on the subject and got very good results. If you drop an e-mail to mr. Ciro, the engineer in charge of the work, he will be glad to share knowledge. The test were made on a family of five bladed surface props, specially designed for low speed applications (displacement), which had been previously tested in the Genoa cavitation tunnel and subsequently in the naples tank testing facility. Numerical results matched quite well the experimental lab test. Regards, Brunello
Old 01-22-2010, 10:10 PM
Leo Lazauskas's Avatar
Leo Lazauskas Leo Lazauskas is offline
Rep: 1711 Posts: 1,243
Were they made to match the results well by a choice of empirical constants? As someone once said, "Give me two free parameters and I can fit a curve to my grandmother's fat ass".
I've seen 6 free parameters and more in some CFD codes.
Cheers,
Leo.
Old 02-02-2010, 11:26 AM
ciro ciro is offline
Rep: 10 Posts: 2
semi-submerged propeller: CFD simulation
Dear Aziziyeng,
a CFD simulation of a semi-submerged propeller is very hard because you have to solve some different “big problems” simultaneously: rotating domains and multiphase flowfields.
In order to solve them, in Flexitab, we developed some specific routines inside one of the most common CFD software. Without them we had always overflow!!
We are studying a five bladed propeller that has been previously tested into a naval tank.
We compared the experimental data with the numerical ones and the results, till now, are encouraging: we found only a small difference between them.
If you have some specific question, I’ll be glad to help you.
Regards
Ciro
Old 04-04-2010, 03:05 PM
sottorf's Avatar
sottorf sottorf is offline
Rep: 37 Posts: 26
Dear Ciro,
that is very interesting. I was recently involved in a low speed application using an Arneson drive (19m boat, 22 knots) and the system worked quite well. Initially there was massive vibration problem with a 4 bladed prop, which disappeared with a 5 bladed version. I therefore fully agree with you that there is a good future in surface drive applications for low speeds.
A colleague and I have been doing some research into applying CFD codes to surface propellers. I am interested to know which code you have used and if you can help us to try and get a working model using Fluent.
Also do you have any experimental data you can make available that can be used for design?
Old 04-04-2010, 11:12 PM
softwaretool softwaretool is offline
interesting.
thanks you so much.
Old 04-09-2010, 11:38 AM
Rep: 10 Posts: 2
Dear Sottorf,
we are very confident in surface drive applications. Still now we are studying theese kind of propellers and their possible applications using numerical codes and also through naval tank tests.
If you want you can visit our web site (http://www.flexitab.com/flexidrive.htm and http://www.victory.it/modellazione3d.html) where there are some images and videos about our studies.
You can also watch a video about a naval tank test carried out at the University Federico II in Naples, at the link below:
http://www.youtube.com/watch?v=7-UVMGc76O0
As you can see we have spent a lot of time and resources for the simulations in the naval tank in order to obtain experimental data that are protected by trade secret. I'm sorry but I can make them available.
About CFD simulation, we are Ansys CFX users and we developed a particoular (and quite complicated) mathematical model for this kind of software.
I used Fluent during my University studies and I'm confident that a mathematical model could be developed with some differences in the definition of the UDF (if i remember well in fluent you have to compile some C++ routine).
Have you already tried to develope something about propeller simulation in Fluent (mono and/or multiphase flowfield)?
If yes, what kind of problem do you have?
Regards
Ciro
Old 04-13-2010, 07:05 AM
PetterM's Avatar
PetterM PetterM is offline
Rep: 197 Posts: 164
What propulsive efficiency did you get at this speed?
Originally Posted by sottorf View Post
Dear Ciro,
www.berserkdesign.com
Old 05-10-2010, 05:03 PM
Rep: 10 Posts: 5
Originally Posted by ciro View Post
Dear Aziziyeng,
Regards
Ciro
Dear Ciro,
I saw your web site. available picture for SPP modeling shows your minuteness in modeling of complicated physics of phenomenon.
I used Ansys CFX and made a preliminary model for a propeller in partially submerged condition using rotating domain and multiphase flow. I used a tight cylindrical rotating domain around the propeller connected to the blades and could to see ventilation around propeller to some extent. but water spray behind the propeller and other details related to blades strike with surface have not been modeled yet. Do you have any suggestion to me for bringing these more details in my simulation?
Can you explain more about your extra mathematical modeling and developed routines? exactly for solving which problems these routins was added to your CFX simulation. I'm going to start a serious academic research in this subject and your hints will be very helpful for me.Thanks alot
Best regards
Old 06-08-2010, 12:11 PM
Lennart_Berghul Lennart_Berghul is offline
Rep: 10 Posts: 3
CFD of Surface Piercing Propellers
For a Customer named Stormfageln www.stormfagel.se
I did a CFD using Ansys CFX 11.0 , it includes air entrainment and cavitation transformation. it corresponds to the measured thrust and I also used the
well known series of the Kamewa propeller in modelscale as Validation
the simulation was presented at FAST-09 which was held in Athens in october -09
I have not a link at the moment but you can request it from me
lennart.berghult@semcon.com
/Lennart
Old 06-09-2010, 07:17 AM
yipster's Avatar
yipster yipster is online now
Rep: 1027 Posts: 3,268
i am by no means an expert but find this very interesting and here my request if no cost is involved to read your simulation results, has Paul Kamen seen this drive?
Old 06-10-2010, 02:25 AM
Rep: 10 Posts: 3
email me
if you email me I will see to that you get the published results
lennart.berghult@bluewin.ch
I have read things ny Paul Karmen but I have had no contact regarding Stormfageln
Old 06-10-2010, 09:32 AM
yipster's Avatar
e-mail bounced but from the stormfagel site this may be the report http://www.stormfagel.se/res/Nyheter...apportjuni.pdf
Best shape for surface piercing foil grob Sailboats 48 11-23-2010 05:47 PM
efficiency of surface drives and surface piercing propellers David Knight Powerboats 7 09-24-2009 05:10 PM
surface piercing propellers seyyed1349 Boat Design 13 02-18-2006 03:42 AM
notebook specs for running CFD codes sasidhar Boat Design 10 07-25-2005 08:31 PM
Surface Piercing Props gyrojocky Props 22 12-10-2004 08:50 PM
