Go Back   Boat Design Forums > Design > Propulsion > Surface Drives
Old 11-29-2006, 03:10 PM
NICKODEMO NICKODEMO is offline
Bravo Skeg Modification
Does anyone have any bravo modifications to increase speed / reduce drag?
I hear that nose cones dont work under 90Mph. Can you sharpen the leading edge or shorten the skeg? Also, why is the skeg angled? Why not have it rounded like a shark/dolphin dorsil fin?
Old 11-29-2006, 04:35 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
Simply taking an angle grinder to the gearcase is unlikely to accomplish much; at best you'll make no difference, at worst you'll do enough structural damage to the housing that it'll fail in the middle of the lake.
If you're into the idea of modifying your drive, aftermarket nose cones are a popular option and the idea that they 'only work over 90' is not true- although high speed is where you'd get the most benefit. Setback boxes are also popular; by moving the drive farther back it can also go higher up (thus less drag). A better prop is one of the most popular and most effective options.
Old 12-07-2006, 09:12 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1528 Posts: 5,518
Nose cones do not stream line the gearbox to go faster, they assist in 'blow out'. This is when the hole from the gearbox will make such a big hole that the prop just looses it,--'blow out'. Fitting a nose cone will give you another 10 -MPH- ish. This usually starts to occur over 80MPH.
Old 01-07-2007, 07:14 PM
NIGHT RIDER NIGHT RIDER is offline
shaped like a fin
you said a mouth full. check out blackfinskeg.com. saw it on fishing u.
Change My Skeg? mcody2005 Boat Design 1 11-06-2006 12:45 AM
Broken Skeg leschj94 Powerboats 2 09-15-2006 07:08 PM
Bronze Skeg JC47 Fiberglass and Composite Boat Building 0 08-31-2006 10:01 PM
removing skeg tom4660 Boat Design 4 01-21-2006 12:28 AM
Bravo Sterndrives guest12020101217 Powerboats 0 03-18-2004 03:00 PM
