#31
| pitch each prop blade has same pitch meaning distance screwed through the water every revolution. each blade uses hp and less blades in the means more efficiency. fastest prop would have one blade but would also obviously be totally unbalanced. fast race boats like hydros have two. surface drives hhave many blades to smooth chopping into the water but only use those in the water each of those pushing the same rate of pitch. |
#32
| still cant see the advantage of this over a sterndrive with propshaft mounted level with hull as many are now ( less on huge diesels as they can take the torque)
__________________ Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers..... |
| Surface drive for v6 ford | jamesp2k | Surface Drives | 4 | 08-10-2010 04:53 AM |
| First Surface Drive ? | MickeyFIN | Surface Drives | 10 | 12-22-2009 12:57 AM |
| Electric Surface Drive | justinDesign | Surface Drives | 2 | 09-23-2007 09:12 AM |
| Stern shape design for surface drive/stern drive | Alik | Boat Design | 8 | 06-15-2006 07:36 PM |
