Go Back   Boat Design Forums > Design > Propulsion > Surface Drives
  #31
Old 03-31-2007, 05:53 PM
tom kane's Avatar
tom kane tom kane is offline
Rep: 287 Posts: 887
2 years ive tried to answer this question
Originally Posted by RANCHI OTTO View Post
NICE! Never seen this picture, very interesting, the transom angle is 0°..and the propeller have traditional profile and works 50% in water...I'm curious....
What are the 2 things on the side? Do you have an idea?
They are for steering,side rudders,not much steering ability there.
tomkane
  #32
Old 03-31-2007, 06:49 PM
RANCHI OTTO's Avatar
RANCHI OTTO RANCHI OTTO is offline
Naval Architect
Rep: 512 Posts: 1,032
Thanks Tom for the info....spectacular boat!
  #33
Old 03-31-2007, 08:05 PM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1693 Posts: 5,875
Originally Posted by charmc View Post
Seafury Marine's surface piercing drives has a standoff distance of only 14 inches/388 mm,
Really? , that is interesting indeed and this thread is definately going the way I was hoping.
Its just niggling that when a Surface drive guru like Paul Kamen says some thing and you cant ask why.
I would really like to know what he meant.
I am hauling out next week and I am definately going to fit a "vacuum break to the trailing edge of the hulls.
I need 3000 RPM for 12KTS and 3400 for 17KTS and only 3800 for 24KTS
(Or there abouts)
The dryer the props get the more they bite, wierd stuff isnt it?
I am hoping that the vacuum break will dry them earlier and reduce my cruising speed RPM.
  #34
Old 04-01-2007, 02:25 AM
tom kane's Avatar
Rep: 287 Posts: 887
2 years i have tried to answer this question
Originally Posted by Syed View Post
So you have found out that I am only a tiny boater. This is Usman, my son in the picture. I am making a shallow water propulsion system for this boat, therefore, I am interested to learn about this subject.
Have a look at a new thread in propulsion..A simple jet for a small boat.
tomkane
  #35
Old 04-01-2007, 04:36 AM
Rep: 756 Posts: 3,328
Looking at the Sea Sled it would seem the "rudders" are more spoilers than rudders , unless they are mounted further out from the hull than the photo seems to show.
AS the units seem to be well along side the hull, perhaps the drag when going straight was lessened , compared to standard rudders?
FF
  #36
Old 04-01-2007, 10:02 AM
Syed Syed is offline
Member
Rep: 8 Posts: 69
Thank you, tom kane !
  #37
Old 07-09-2007, 04:10 AM
Janamon Janamon is offline
Rep: 10 Posts: 10
Seafury
Originally Posted by Frosty View Post
If clean green solid water is important then a knife sharp trailing edge on the stern and a prop fitted say 1 foot away would give a perfect place for the prop?
8 degrees seems to be the standard for fixed surface props. Possibly because the difficulty in obtaining better isnt worth the effort.
Interesting that Seafury who also make a fixed drive specify on the web site what they call a vacuum break. This is a very sharp trailing edge. They say this is important for surface propellers.
Now taking all this into consideration and Arneson moving further away. Perhaps the answer is, it simply doesnt matter if the prop is close to the transom.
I wish Paul Kamen would have aswered my querie.
I dont see how a prop further away cause better efficiency. If the shaft ange on both is 8 degrees then pwer is being trasmitted up the shaft at that angle. Why does it matter where the propeller is on that shaft.
Seafury require a vacuum break because of it's 45 degree transom. If the vacuum beak wasn't there the water would follow up the transom, effectively burying the prop..
  #38
Old 07-10-2007, 01:43 AM
Frosty's Avatar
Janamon, Yes that absalutley correct, but no.
I recenty hauled out my cat and extended the hulls by 2 inches making a knife sharp edge on the planing section of the hulls transom. I did this because I thought that maybe I did not have the props out high enough, and that the props would be burried.
It made no difference what so ever.
I had experimented for hours with models of transoms and a hose pipe and it is easy to sea a big difference in the wake of hulls with the slightest roundness of the transom.
Handing the helm to my girl freind I left the bridge to go down and look at the props. There was no difference at all. Not even a difference in the rooster tali wich is only say 10 feet and about 4 feet high at 18KTS.
  #39
Old 07-12-2007, 07:41 AM
Rep: 501 Posts: 1,767
Reason is simply
Surface drives require air in prop. If you put prop too close to transom then prop is going to be fully submerge at anything above idle speed. The heavier the boat the worse the problem. You have to move prop behind wake, after the hump or at least move prop higher. With Arneson you have to trim up to get over hump then trim down when you get to speed. I put surface drive on a shallow draft boat- no problem but when I put it in heavy boat - I couldnt get prop into air. I am looking for ways to ventilate prop like powervent using exhaust. Like I said the draft/weight of boat has a lot to do with it.
How to clean 30 years of muck out of folkboat bilge jmennell Wooden Boat Building and Restoration 2 11-22-2006 01:56 PM
Amphibious Cars - 100 years of kach22i Open Discussion: All Things Boats & Boating 8 01-08-2006 10:55 AM
Now im back after 2 years of silence Peter H Open Discussion: All Things Boats & Boating 1 01-02-2005 02:05 PM
looking for answer to puzzle kerrie Boat Design 1 05-22-2003 11:26 PM
In 10 years?? duluthboats Software 16 06-10-2002 06:34 AM
