| The Wind Powered Sail-less Boat Hello everyone, I am an engineering student in the U.K. and have just been given a project to design and create a working model wind powered sail-less boat. Thats right a boat powered by the wind but without a sail. Ha ha...Anyway a bit about the project. The hull is approximately 1.5m x 0.4m (at widest section). We have 2 hulls and can therefore construct a catamaran design. (likely) It can hold about 20kg max per hull, without buoyancy aids. The boat does not need to travel with any significant speed but must be able to complete a short slalom course and make it back to shore if the wind speed drops....therefore some form of energy storage must be implemented, although this comes with a hitch. It must be mechanical energy storage ie flywheel, elastic band or spring. The contraints of the project allow the use of battery powered servos to ideally operate rudders but this is the only electrical storage permitted. So far, our team has decided to use a vertical axis wind turbine, probably Darius, to provide the core power. This obviously has the advantages of being able to catch the wind in any direction and it's weight is more evenly distributed than a horizontal axis wind turbine, helping with balance issues. This is probably the sort of turbine we will construct ourselves due to it's small scale nature and also operate with mechanical power transmission to attach/gear some form of mechanical storage device. We have not yet constructed any part of our model boat as we are still in the early stages of the analysis. I have therefore made this post to generate some interest in the project and also run our initial ideas past everyone. So what do you think? Is this possible? Ha ha, let me know your thoughts! Thanks, Duncan |
| If you do a search on wind powered models in this site - you will get page after page after page of info. Its been done to a lingering death in here. Yes it will work, no Darius turbines are not the most efficient, (despite what you saw on WaterWorld) You may want to search for Flettner Rotors as well. |
| Great Project! I think it's an imaginative idea. As i have not got involved in the propulsion debate listed above, i went and did a little checking on the subject. I found some non technical but contextual bits at http://en.wikipedia.org/wiki/Flettner_ship regarding the Flettner Rotor. Do keep us up to date it sounds fascinating! ![]()
__________________ By Chris author boatpride.com Virtual sailing resources and products, an interactive, multi media experience! Leave a video / audio /written comment! |
| I think it will work but not dead to windward. Friction or resistance of the turbine will be greater than the force generated by your propulsion. Maybe couple your flywheel to your turbine so when it needs to go dead against the wind then the inertia of the flywheel will help it through. |
| Didnt Jaque Costeau have something like that? It looked like a big pole standing upright in his boat. I must be the Dolt, because I didnt see how it was supposed to power a boat. |
| Instead of a flywheel energy storage , you might consider a hydraulic pump/accumulator/motor . This will store mechanical energy more efficiently.
__________________ M.A. Steele Venture Hulls (Canada) |
something like: Turbine > compressor pump > Pressure Tank > pneumatic motor > drive shaft to your screw/prop/etc. It'd have the disadvantage of having to wait for it to build up a bit of pressure in the beginning, but then you'd always have pressure reserved in the tank for fighting your way into the wind, or for "limping home" if you lose your wind. I'd HIGHLY recommend you attach one of your servo motors to the regulator though, so you can control the storage/release of the pressure from shore, if you use this method. Last edited by robherc : 01-05-2009 at 12:11 AM. Reason: I can't spell today |
| Windmill or Wind Turbine- powered boats: how many are out there, and are they viable? | Duma Tau | Projects & Proposals | 503 | 08-13-2010 02:00 PM |
| Why my boat can't move forward in strong wind??? | redmapleleaf | Boat Design | 38 | 11-25-2008 02:38 AM |
| True wind/apparent wind? | pygmalion | Boat Design | 5 | 12-09-2004 07:52 AM |
| How close to the wind can a boat sail? | tonyr | Sailboats | 13 | 06-13-2004 08:35 PM |
| Sail horsepower vs wind force? | tommc | Sailboats | 3 | 02-15-2004 02:49 PM |
