| Will a DEEP spade rudder prevent chine tripping ? Is that a true statement for a constant 23 degree deadrise powerboat? I have read that, the deeper the rudder, the more heeling over into the turn direction. Should that be taken as a total elimination of chine tripping on a deep V at up to 40 to 50 mph ? Obviously we start slow & keep cutting off small amounts of the bottom of the rudder untill maximum speed sharp turns can be taken. |
| Ok Could you tell me what is causing a chine trip when the hull is leaning 30 to 40 degrees into a high speed turn in about 1' to 1.5' waves ? Rich |
| The angle of the rudder has a huge influence too.
__________________ Gonzo |
| gonzo Do you mean the vertical shaft angle if it is not vertical or the front & rear edges ? |
| If the shaft is not vertical it influences whether the boat turns bow up or bow up.
| I asked this question based on the reference material. It could be incorrect. |
what you are referring to is something else im sure and not chine tripping !! ![]()
| I thought chine tripping occured when a boat had enough speed in a turn that the boat SLID sideways fast enough so that when a wave struck the chine high enough, the boat would use the sliding momentum to cause a sideways flip. COG above the water line. Power boats. |
Like gonzo will explain i hope the angle of the rudder shaft in relation to the keel is very important and has the effect of digging the back of the hull down or raising the back of the hull up . But he can explain !!! The effectiveness and size of the rudder plays a big part in all this and speed as well . Chine tripping is something that happened with shallow dead rise ,very flat bottomed hulls where the outter side is just above the water surface and during the bounceing action the outer chine clips the water and digs in !!! and yes will flip the boat or give you one hell of a fright . the best example i can think of is the Glen L Missile hull that has a non trip chine on the last 1/3 of the hull at the rear . The chine has about a 45degree angle on the chine to make the chine lift and ride over the surface of the water and not dig in !!
| I agree with you. baeckmo got me confused with his NO answer. I have passengered in 1 small Aluminum OB boat that could be at about 40 mph cut the wheel to the steering stop. That caused a sharp enough lean / heelin that I was pushed down hard enough to exhale. Fantastic safe feeling. 180 degree turn in 3 to 4 seconds we were headed back the opposite way & accelerating to WOT again. ![]() |
| The following copy appeared in our 1962 catalog: The MISSILE is a bundle of greased lightning compacted into a sleek hull form. The v-drive hulls are without a doubt the fastest type monoplanes available. When powered with the right power plant, the MISSILE will "take off" as if heading for outer space. When handled sensibly, this hull will still be as safe as is possible at the higher speed ranges. The flaring anti-trip chines will prevent tripping on turns, and the wide beam gives positive stability at high speed. Use her as a pleasure craft or ski boat. Whatever the use, the MISSILE is at home in the fast lane. I almost built one of these Glen L missile boats way back in 62 but got married instead !! was and still is a stunning looking boat even after all this time !!! ![]()
| the same typt of boat ![]() ![]() These are the best examples i could find to give you the idea of a anti trip chine and also the absence of deadrise of hulls that used to have tripping problems way back . If this is happen these days designers have learned nothing !!
| Semi spade rudder construction details | ldigas | Powerboats | 3 | 10-18-2011 12:28 PM |
| Partial Skeg/Semi-Spade Rudder with Downward Slope and Ceramic Blade | Bahama | Boat Design | 0 | 07-18-2010 01:35 PM |
| Rudder adjustment on 33' deep-v hull | Purple Haze | Boat Design | 1 | 12-28-2008 12:32 PM |
| How to prevent rust from spreading on trailer | LAURASDAD | Boat Design | 6 | 04-29-2008 05:39 AM |
| help tripping bracket design | sujith | Boat Design | 1 | 07-24-2006 05:57 AM |
