Old 12-11-2007, 02:54 PM
jwnsc jwnsc is offline
Rep: 10 Posts: 3
Twin Keel Inverse Stability
Hello, I've been lurking for quite awhile and thought I'd take a stab at posting a question. I am reviewing possible twin-keel metal designs and have done a moderate amount of internet research in the last year of so. While I am very familiar with the pros and cons of twin keels, I have yet to run across any data on whether the inverse stability of a twin-keeled hull is increased, decreased or is about the same when compared to a mono-keel in all it's variations, e.g. full, shoal, short fin, centerboard etc. My intuition tells me that everything else being equal, a twin keel boat turned turtle would be slower to right itself than if the same boat was a mono-keel. A year or so ago, someone on this forum asked the same question with many others about twin keels but the inverse stability inquiry didn't seem to get answered. I guess I'm hoping to be directed to some sort credible tank testing data, reliable mathmatical formula or first-person anecdotes that would suggest that a twin-keeled boat is not dependent on the next huge wave to turn it back over after it is capsized. Thanks.
Jim Williams
Charleston, SC
jwnsc@msn.com
Old 12-11-2007, 04:37 PM
Guillermo's Avatar
Ingeniero Naval
Rep: 2041 Posts: 3,567
In my opinion ALL other things being equal, including total keel(s) area and volume, and asuming a uniform distribution of the same amount of ballast weight through keel(s) body(ies), inverted stability of a twin keeler with keels of normal proportions should present a higher area under the negative side of the GZ curve than in the case of a fin keel of also normal proportions, because of the relative higher position of the ballast's COG. But this is only a theoretical 'divertimento', as not ALL things are equal.
Cheers.
Guillermo Gefaell
Moon Yacht Design
Old 12-12-2007, 09:58 AM
dodo74 dodo74 is offline
Rep: 10 Posts: 4
My opinion is, that stability (righting arm) depends on location od COG and COB in specified angle of heeling
...nice explanation you can see at
http://uk.geocities.com/faymarine@bt...ting_curve.htm
...so if you will compare two identical boats - one with twin-keel and one with mono-keel the stability will be the same if COG of mono-keel and COG of twin-keel version will be in the same location - see the picture
so, my conclusion is that the stability doesn't depend on if it is a mono or twin keel but on the construction of each type
what do you think ?
Old 12-12-2007, 02:23 PM
Rep: 1623 Posts: 1,483
If BG and GM and hull form are the same, then the only difference would be in Imxx which controls the rate of roll, not the stability. However, as Guillermo pointed out, in the actual practice of just swaping twin keels for a fin keel, BG and GM and Imxx are are all likely to be less for for a twin keel and therefore you would expect less area under the positive GZ curve and more negative GZ area. This would mean that the twin keeler would be more stable inverted....not that it really would matter as a well designed hull form should keep that area low with either keel form.
Now if it's a twin keel scow.........
Old 01-11-2008, 08:12 PM
Member
Rep: -33 Posts: 951
Twin Keel stability
For a given draft the inverted stability of the twin keeler would be exactly the same as that of a single keeler of the same draft. Shapes above the decks have a great influence on ultimate stability. If you consider a beach ball, a tiny ballast ratio gives 100% self righting ability. With a raft shape even a 75% ballast ratio wont bring her back once inverted. So compare the midship section with that of a beach ball. A trunk cabin with a high camber adds greatly to ultimate stability. A flush deck with wide beam, resembling a raft when inverted, has poor ultimate stability. The bouyancy of my wheelhouse full of air has the equivalent effect on ultimate stability of adding another 3,000 lbs of ballast.
Thus you can get at a glance a good idea of the chances of ultimate stabilty problems on cruising boat
Brent
Old 01-11-2008, 10:23 PM
Rep: 10 Posts: 3
As designed, does the BS 36 twin-keel have the same draft of a BS 36 mono- keel?
Old 01-12-2008, 04:53 PM
Member
Rep: -33 Posts: 951
twin Keelers
No . With the deadrise the twin keel 36 footer has 4 ft draft and the sigle keel ,being on the centreline, draws 5ft10 inches empty.
Brent
Old 01-13-2008, 06:09 PM
Rep: 10 Posts: 3
Twin Keel inverted stability
Thanks Brent, PM sent.
Twin keel research MikeJohns Boat Design 125 06-16-2009 11:44 PM
twin single keel Garth Boat Design 5 08-18-2006 06:21 PM
Twin Keel Righting Moment Willallison Sailboats 23 04-04-2006 01:22 AM
Twin keel placement Moss Wooden Boat Building and Restoration 6 02-28-2006 12:07 PM
twin keel design Tom Triglav Boat Design 12 09-28-2005 08:41 PM
