| Turning issues G'day all I recently purchased a second hand fiberglass 1968 Wiltshire "Skiflight" 4.70m in length. It has a murcury 65 outboad, a bit underpowerd i think. The hull is a very smooth "V" hull at the front that changes into a flat bottom at the rear, dose this hull type have a typical name, please correct my wording as i am new to the boating jargon. haha. When i excuite a turn at any planing speed the boat rolls over to the side before more input is needed to inituate the turn, it feels quite unnatural im just curious is this normal to this type of hull. Now the hull has no ribs what so ever. And I think its the terminology "flares" please correct, the ribs that run up higher on the side of the hull that touch water in a turn are quite small. Any way that i can imporve the turning ability of this craft would be great, some help for this first boat owner would be muchly appriciated. Travis ![]() |
| Some boats do turn better than others, However if it does it both ways theres not a lot you can do. I assume you mean rolls into the turn --not out? Firstly make sure the cavitation plate is approx 2-3inches bellow the bottom of the boat. It would probably be better if you attempted the turn at a higher speed. Perhaps you need a little more time with it. |
| Prop not turning | caravelle | Outboards | 5 | 08-06-2007 10:00 PM |
| turning issues | talbot.s | Stability | 7 | 06-24-2007 09:31 AM |
| Turning my boat over - need some hints | rico | Metal Boat Building | 16 | 08-11-2006 10:15 AM |
| Please Help - Turning Boat Over | rico | Boatbuilding | 7 | 07-15-2006 10:21 PM |
| High Speed Turning Dynamics | Evolution Yacht | Boat Design | 8 | 04-15-2002 04:15 PM |
