| trim and stability i need to prepare a stability booklet for a Offshore Supply vessel. Please advise how to go about it step by step.From Lines plan to Offset table. How to prepare Hydrostatic curve,KN curve etc. ![]() |
| first, you need a software. |
| You have some basics on stability here: http://web.nps.navy.mil/~me/tsse/NavArchWeb/1/toc.htm Cheers. |
| Without wanting to sound rude, contact a local Naval Architect and pay someone to do it. Even if you muddle your way through it there is a good chance that the authorities won't accept it if its been prepared by an unqualified person. There are peoples lives at stake when you prepare this type of thing. Its not the right place to cut corners.
__________________ Chris Tucker Marine Design Your Boat Your Way. www.ctmd.com.au |
| trim & Stability booklet I am a Naval architect and can prepare a trim and stability booklet for you. But the boat is to be inclined. Then the readings are to be taken for the calculation of the center of gravity. The hydrostatic calculations can be done using the Lines plan details. if you can mail me the the dimensions and displacement of the boat. Is this vessel classed ? This involves a lot of work including calculations. Is it a new boat or old one. Yes |
You'd need a lot of data, not just a lines plan, but tools if you're doing it manually... |
| yeap it's need a lot of calculations so please concern any naval architect who is having proper experience with the stability calculations |
| Stability on a Cigarette.... Trim Tabs | CigaretteDesign | Stability | 2 | 01-03-2008 07:07 PM |
| No Power Trim | san | Sterndrives | 0 | 09-07-2006 06:24 AM |
| Need help with interior trim | kart 35 | Boatbuilding | 0 | 06-16-2006 02:30 AM |
| just the trim | hannahsmom | Wooden Boat Building and Restoration | 2 | 06-12-2005 06:50 PM |
| Trim Tabs | stevel | Powerboats | 0 | 09-20-2004 04:13 PM |
