| ...tpc / Tpi... Hi all, I need a little help in deriving ratio between metric and imperial unit immersions ( Tonsmetricpercentimeter / Longtonsperinch ) Obviously we need less mass to immerse a boat one centimeter then one inch ( 1 longTon correspond to 1.016 metricTon ), but whatever trick I pull from the bag I keep geting larger than one ratio ( 2.5 to be precise ) What am I doing wrong ![]() |
| 1 lt/inch = 1.016/2.54 mt/cm = 0.4 mt/cm 1 mt/cm = 2.5 lt/inch
__________________ Guillermo Gefaell Gestenaval S.L., Naval Architecture & Marine Engineering Moon Yacht Design |
| Thanks Guillermo, I'm geting the same result...but the common sense tells me that TPC should be less then TPI ( ratio TPC / TPI less than one ) ? |
| ....TPC should be less then TPI.... And they are! 0.4 < 1
| ...1 lt/inch = 1.016/2.54 mt/cm = 0.4 mt/cm 1 mt/cm = 2.5 lt/inch... mt/cm = TPC lt/inch = TPI according to your second line: TPC = 2.5 TPI TPC / TPI =2.5 > 1 ...still confused ![]() |
| ...I've checked in one of Hydromax's sample models ( varying units for same waterplane area ) and got : TPC = 1.097 tm/cm TPI = 2.743 lt / inch ----------------------- So TPC/TPI = 0.4 , Inverse what we derived for the same ratio ( 2.5 )...I'm not very good in dimension analysis..Anyone out there ??? ![]() |
1 mt/cm = 2,5 lt/inch (1/2,5) mt/cm = 1 lt/inch 0,4 mt/cm = 1 lt/inch This implies you need less weight to sink a boat 1 cm than to sink it 1 inch (as is evident). An example: If you take a parallelpipedic hull, of 1 sqm section, floating in fresh water (density = 1), you need 10 kg to sink it 1 cm but you need 25,4 kg kg to sink it 1 inch. Check: 10 kg = (25,4*0,4)/1,016 What's the doubt.... ![]()
It's clear now, thanks ! ' ...open mind for a different view... ' |
| Veritas lucet omnibus.... ![]()
| Tempus omnia revelat ![]() |
