#241
Why have you let the rain put you off getting wet under a dripping hull? PDW |
#242
And believe it or not, I had been neg on reputation by some nameless individual and this was the message/reason; "You disregard the proven" I have a good idea whom it may be but he can rest assure that I will not retaliate with such pity - I only neg insulting and rude behavior when called for which is a rare event.... Now my question to this person; what was proven on this topic and what did I disregarded Very seldom have I neg someones reputation over the years, but at least I had the balls to put my name to it. Now do you have what it takes to comment on your statement in a post?
#243
PD I am an Aussie Old saying believe half of what you see and nothing of what you hear A wise ole owl sat in a tree the less he said the more he see the more he see the less he said What a wise ole owl was he So in you retirement , get off here, go catch a fish or a cold or whatever smile and dee world smiles wiv you mate |
#244
Been running an angle grinder most of the afternoon, a nice drink seems about right now. I still think the origami concept has a lot going for it provided you are happy with the restricted range of hull shapes. If the BS 36 is on the tender side, it's not the only one out there. I recall George Buehler saying a number of his designs were tender. PDW |
#245
Well the stability still requires an experimental confirmation of kG aka an inclining test. It also merits some discussion of sealed masts and their real potential contribution to the RM curve wrt inversion. I could have asked Jeff to delete the post since it's slander, but it's better to leave them standing for others to see the measure of the man. Remember the old adage?, If you want to get the attention of an ornery old bull you hit him with a 2 by 4 somewhere tender, nothing else gets noticed. Slowly and painfully we all learned that about Brent. You only get facts through to BS in an exchange just short of violence, bit by bit he's dropped his most bizarre beliefs because of these exchanges. That can only lead to the common good IMHO.
#246
Said the livery stable owner to the Wright brothers. Said the scribes to Guttenburg. Said the telegraph operator to Alexander Graham Bell. I can imagine a stone age conversation going something like this :" Why Trog invent wheel? That not proper way. Do it proper way. Drag it. That how it's done . Wheel not how it's done . Tell Trog, "Don't be so lazy." Trog lazy bum." History repeats itself. |
#247
__________________ Henry Reeve, P.E. |
#248
| ABS Rules for Offshore Yachts 1.5.2 The committee is at all times ready to consider alternatives and scantlings which can be shown through "EITHER SATISFACTORY SERVICE EXPERIENCE'"or a systematic analysis, based on sound engineering principles, to meet the overall safety and strength standards of the guide. Done! It appears that the static stability tests advocated by Tad and Wynand , such as timing roll period, have nothing to do with self righting ability, but deal only with static stability. This can be enhanced by excessive beam, and flush decks , which are responsible for problems with reduced AVS and self righting ability, as was pointed out by Angus Primrose and Tony Marchage. Thus sticking to ISO rules actually encourages boats with self righting problems, and could lead one to a boat which is anything but adequately self righting. Excessive beam also negatively affects directional stability and downwind control. Narrower boats are for more directionally stable, and easier to control downwind. The changes in Tads stability curves, as the factors affecting it are pointed out to him, demonstrate clearly ,how a factor can change the results drastically . I've seen curves for another design, which show the cabin and wheelhouse buoyancy change the AVS by over 40 degrees. Begs the question "What other factors have been left out?" |
#249
#250
#251
To go back to the beginning and re-cite because you apparently don't understand......... the static curve of righting arms is a universally accepted representation of the "righting force" exhibited by a particular vessel at various heel angles up to and including 180 degrees (capsized) ......Thus the static curves of righting arms of your design which I have produced and published do indeed have something to do with the subject vessel's "self righting ability".
#252
| Jack.... Waving one rule around while poking at another seems a bit odd...... The ABS stuff has nothing to do with stability........and nothing has been "shown","based on sound engineering principals"........Do you seriously believe you can walk into ABS and tell them "there are hundreds sailing" and "They haven't broke yet"....and your statements will be accepted and your design will be classed by ABS? Never mind they haven't dealt with vessels under 79' in many years and the boilerplate you are citing is in "OFFSHORE RACING YACHTS", which has some problems to begin with and was last published 17 years ago..........
#253
cant wait for the humble bee to put in an appearance again..Quote:
Seems like he has a ghostwriter with a little boat know-how posting on his behalf..... Recently someone also made a similar remark at a post not believing is BS/JH rant.
#254
I'd give you some "Rep" points,but of course,I can't! you see how it goes here... ![]() otherwise, off on tangents again,are we? ![]() it still looks like a pretty standard boat,to me. |
#255
You claim these boats don't pass ABS rules, and when your error is pointed out, you claim ABS is irrelevant, contradicting your earlier claims. It appears that what was done with ISO, was to take initial stability calculations for power boats and try apply them to offshore sailing craft, which are a totally different ball of wax. |
| in the preliminary design, how to check and made a stability curve | tessario_lukas | Stability | 1 | 04-13-2008 11:43 AM |
| very importan need tocalculate cross curve of stability KN | s3dany | Stability | 5 | 01-08-2008 11:07 AM |
| Egret Sharpie {Munroe} stability curve | Lassuuu | Stability | 10 | 08-24-2007 06:15 AM |
| Brent Swain | Boatbuilerfx | Boat Design | 3 | 03-10-2007 09:50 PM |
