Old 06-13-2009, 12:37 PM
Skipperstu Skipperstu is offline
Rep: 10 Posts: 2
STIXS figure for Bavaria 44
Hi
Can any one help with the STIX figure for a 2002 lead keel bavaria 44, I need the figure for a racing certificate and the manufacturer say they cant find any information.
Thanks in advance
Stuart
Old 06-13-2009, 03:02 PM
TeddyDiver's Avatar
Gollywobbler
Rep: 1298 Posts: 1,991
Thats for sure a BIG lie.. They have to know, they anyway had it categorized..
Old 06-20-2009, 12:24 AM
Guillermo's Avatar
Ingeniero Naval
Rep: 2041 Posts: 3,567
Of course they are lying . The fact is most manufacturers do not want the public knowing their boats' STIX numbers, for the people not comparing with other brands. Tell them so and ashame them.
I have searched for the Bavaria 44 at the RYA Stability List (http://www.rya.org.uk/KnowledgeBase/...ilitydata.aspx) but, although listed, its STIX doesn't appear. Sorry.
Cheers.
Guillermo Gefaell
Moon Yacht Design
Old 06-20-2009, 06:10 PM
apex1
Originally Posted by Guillermo View Post
Of course they are lying . The fact is most manufacturers do not want the public knowing their boats' STIX numbers, for the people do not compare with other brands. Tell them so and ashame them.
Cheers.
Thanks for the link Guillermo. The RYA is quite very frank on that issue:
Since June 1998 all new recreational boats sold in the EU have been required by law (the RCD*) to have
undergone a stability assessment with the preferred method being the application of ISO 12217. This means
that all but a very few new monohull ballasted sailing boats sold in the UK (including all of those imported)
should have had a GZ / RM curve generated, their displacement and AVS determined and a STIX calculated.
To this end, by the time you read this, the RYA will have circulated a copy of this article to builders together wi
a request for stability data on their models. Where this has been received it well have been published on the
Technical part of the RYA web site. If the data is not there then ask for it and also suggest it should be sent to
the RYA. If it’s still not made available then smell a rat.
And thats good!
to be found here:
http://www.rya.org.uk/assets/technic...ty%20Intro.pdf
Regards
Richard
Old 06-25-2009, 04:49 AM
Martijn_vE's Avatar
Martijn_vE Martijn_vE is offline
Marine software developer
Rep: 401 Posts: 251
If you know what category your yacht falls into (A, B, C or D) you know at least the range of the STIX number, for example Category B ranges from 23 to 32. A bavaria 44 is probably meant for open ocean (catergory A), so should have a minimum number of 32. Do you need to know the exact number, or is a safe estimate (32) sufficient?
Old 07-03-2009, 07:57 AM
Rep: 10 Posts: 2
Thanks to everyone that tried to help on this matter, the reason I was asking is the Royal Ocean Racing Club need to have a STIX figure before we can enter the yacht into some of the races. I have emailed them the builders certificate which states it is built to cat A and should have the minimum requirement but they are still asking for the figure.
The bavaria dealer have asked the factory several times and still no luck.
Old 07-03-2009, 06:02 PM
apex1
If you drop them a mail with a link to this thread, I would bet there will be a answer whithin a day!
Oder sitzt Ihr in Giebelstadt auf den Ohren wenn es um Kundenbelange geht?
Regards
Richard
i use archicad to figure how will look RSALVAREZ Software 0 10-29-2008 04:32 AM
Bavaria 38 - Keel bolts and GRP Laminat brunohamm Boat Design 3 10-14-2007 05:50 PM
Bavaria Match 42 lost its keel... ErikG Sailboats 82 05-28-2006 03:45 PM
Bavaria Match 35 Keel Profile koc Boat Design 5 05-02-2006 04:00 PM
Tandem? Keel on Bavaria Andrew Adams Sailboats 11 02-15-2006 07:59 PM
