Old 12-08-2009, 07:11 AM
Aryavrat Aryavrat is offline
Rep: 10 Posts: 2
Stabilty
In Autohydro, I loaded a GF file of a ship when I gave fixed draft of 7m and then solve weight.Then i clicked the Solve button for equilibrium it gives me a very large TRIM of near abt 75 deg .
Old 12-12-2009, 12:23 AM
CowMan CowMan is offline
Naval Architect
Rep: 10 Posts: 8
Aryavrat, some of the common causes of such results are related to the hull geometry file - if the GF file defines a single side of the vessel (and Autohydro is not mirroring automatically), if there are overlapping sections, or if the draft of 7m exceeds the deck edge, crazy values are likely. If you have another program (such as Deadweight or Rhino I believe) which can view the file, open it up and double-check everything is consistent and bounded.
My memory of Autohydro is sketchy at best, however if you have any weights assigned --- check the distance to origin. If a masses LCG is accidentally set with the wrong sign (+/-), it will overhang the vessel and induce substantial trimming moments.
Old 12-14-2009, 06:06 AM
Rep: 10 Posts: 2
CowMan
The problem is solved, actually after loading the gf file and setting the given draft. I have to solve for lcg, otherwise autohydro will give some random trim values.
Thank you for your concern
prawn trawler stabilty Sheepy Stability 25 02-21-2010 03:23 AM
Stabilty solutions needed. ahmugz Stability 6 11-12-2009 07:06 AM
roll patterns and stabilty Guest62110524 Boat Design 10 08-24-2009 07:54 PM
