Old 07-25-2009, 11:06 AM
CatBuilder CatBuilder is offline
Rep: 28 Posts: 24
Stability with 5.2 to 1 L/B Ratio
I'm still looking at hull shapes... and I'm looking at long, narrow powered boats. My question is regarding stability and L/B ratios.
I have a specific boat size in mind which comes out to a L/B ratio of 5.2 in a small powered vessel (about 40 feet LOA/LWL)
In order to make this boat as stable as possible, is it customary to put power, batteries, etc... all down low below the waterline, or do you need to add a full length "mini keel" from bow to stern to keep things upright?
Or... am I still thinking too much like a sailor?
Is a 5.2 L/B ratio a stable power boat, if designed to normal power boat conventions? (I realize I haven't given all the facts with weight distribution, etc...)
Lastly, is there a good resource (on the web) to start doing stability calcs?
Thanks.
Old 07-25-2009, 04:00 PM
apex1's Avatar
apex1 apex1 is offline
Steamer
Rep: 898 Posts: 3,630
Thanks.
Am I right to assume that you are asking for a monohull? Your "name" confuses me a bit.
Richard
Fortior est qui se quam qui fortissima vincit Moenia.
Old 07-25-2009, 04:57 PM
Rep: 28 Posts: 24
I know, Richard. My requirements just changed because of the wife. My name no longer suits me at all. Yes, a monohull.
Old 07-25-2009, 05:17 PM
apex1's Avatar
Steamer
Well I´ve given you some hints on the other thread. Whenyou´re through with that you might have many questions answered already.
Regards
Richard
Old 07-26-2009, 07:45 PM
Willallison's Avatar
Rep: 993 Posts: 2,968
It's generally a good idea to always place weight as low as possible. There are exceptions - for instance on vessels with high initial form stability weight is sometimes used to slow the roll motion for a more comfortable ride.
Will
Imaginocean Yacht Design
Old 07-26-2009, 07:51 PM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 659 Posts: 1,709
Also depends whether you have any tumblehome/flare too..this can aid large angle stability
Old 07-26-2009, 08:16 PM
apex1's Avatar
Steamer
There is a comment on Dashews Windhorse site related to that issue. I assume CatBuilder (well, not longer) will still stumble through that site.
I had Jacuzzi´s to serve the motion dampening (not exclusively) on my larger vessels.
Indeed a lower initial stability is preferred on passagemaking motor boats, compared with sailing boats of equal size.
ratio tlar633 Multihulls 1 07-24-2009 07:50 AM
Outdrive ratio?? Joka Sterndrives 4 06-03-2007 10:05 PM
Sepeartion Ratio navarch_hish Multihulls 1 07-26-2006 10:01 AM
1:78 ratio vs. 147:1 ratio ... which to choose? ezfriday Propulsion 18 02-18-2006 08:21 PM
ratio bevan Boat Design 1 03-21-2004 07:20 AM
