Old 09-16-2009, 01:24 AM
mwatts's Avatar
mwatts mwatts is offline
Martin
Rep: 28 Posts: 66
Stabalizing a small steel boat
Someone I want to help, has a small problem with his steel boat. He's worried it's not stable enough, especially when he wants to take it out with his kids.
Here are some pictures of the boat:
LOA = 580 cm
BOA = 180 cm (at the bottom it's 140 cm)
Draft is approx. 20 cm.
My first suggestion was to weld on a keel. But that's not an option, because the boat is operated in shallow waters (e.g. he has to use the outboard's shallow water drive to get home).
So I thought I'dd ask here. Has anybody got any idea's to improve stability without increasing the draft of the boat?
Old 09-16-2009, 01:28 AM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 1933 Posts: 3,025
Add 'fenders' full length (just like you see on RIBs)....nice foam filled ones so they do no lose buoyancy when damaged. These can be glued or rivet/bolted on. Therefore when the boat heels, she has 1) increased buoyancy and 2) a greater righting moment.
Old 09-16-2009, 02:34 AM
mwatts's Avatar
Martin
Rep: 28 Posts: 66
Won't fenders make her plough thru the water even more than she already does?
Old 09-16-2009, 06:02 AM
Naval Architect
mwatts
I have no idea, since i have no idea what your boat is like when underway, no video or pic showing this. Bit difficult to ascertain the performance when non given in the original post!
Just place the fender underneath the black rubber strip..or replace it with the fender.
Old 09-18-2009, 07:51 PM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,401
Surely the designer has done the stability calculations ?
If he hasnt had stability calcuations done, I would suggest he doesnt even go out on his own.
The easiest and cheapest ballast aid for a tippy boat of this size are four of five bags of sand in the bottom
In fact, he could get sandbags with the equivalent weight of passengers, put them all on one side to test the stability. It would be a quick way to see how 'tender' the hull is.
Old 09-19-2009, 12:20 PM
mwatts's Avatar
Martin
Rep: 28 Posts: 66
To be honest, I expect the designer of this boat to have started pushing up the daisies a good two hundred years ago. It's a traditional dutch "vlet" and has been copied a million of times.
I think however this version has a higher L/B ratio than usual. It will go faster, but I guess the tradeoff is less stability than the beamier versions.
Old 09-20-2009, 06:40 PM
rwatson's Avatar
So, basically its *not* a traditional design, despite the similarity in lines. There are heaps of comments all over these forums and the web about the dangers of "its just a little change"
Practical experimentation with real weights is probably the easiest and cheapest way to prove stability.
Old 10-16-2009, 02:46 PM
Rep: 749 Posts: 1,314
Looks like a nicely built boat, abit odd, and it is probably not entirely hopeless. Do as Rwatson says. Put several sandbags in the BOTTOM of the boat. Move 'em around to test righting moments. secure them at the centerline of the boat and then try it with passengers. Keeping the bulk of the weight very low will be useful. The alternative solution is to give the boat a decent burial.
The boat looks like a Bolger Gypsy run amuck. The steel boat has too much angle on the sections that we might call the lower strake. Five piece boats like this can be designed to work very well but this does not appear to one of them.
Old 10-16-2009, 03:09 PM
Rep: 1493 Posts: 7,447
Nice looking boat. With that flare she should have a fair amount of reserve stability. What does the owner consider unsafe? Those boats tend to be a bit tender and then stiffer as a chine comes off the water
Old 11-05-2009, 11:40 AM
nukisen's Avatar
nukisen nukisen is offline
Rep: 114 Posts: 383
As far as I can see this looks to become a stable boat.
You did ask for a sugestion to make it more stable without increase te draft.
Then take a look at Matt Laydens solution.
One of the smartest things I have ever seen. Usually used for sailbots. And with a lot of different functions.
http://www.microcruising.com/Sketch1.htm
As you can see on this page, the boat does have a little list at the bottom.
This list does increase the stability. Caused by the displacement increases at thae sides. The draft will even get smaller. And also works like a keel when you heel the boat at side. (specially for sailboats)
Of course you can try this option.
The more I learn the more I do understand that I do not understand. :)
Old 11-05-2009, 11:42 AM
nukisen's Avatar
Rep: 114 Posts: 383
Ahhh also this lists does move the center of gravity downwards (cog).
This will increase the stability a lot.
Old 11-05-2009, 01:29 PM
mwatts's Avatar
Martin
Rep: 28 Posts: 66
Nukisen, you are referring to the "chine runners" in the pictures? I will forward the suggestion. Thanks.
Hoping to finish the design and build of Karamu this decade...
Old 11-08-2009, 06:54 AM
nukisen's Avatar
Rep: 114 Posts: 383
U r welcome Martin!
Yes i did refer to chine runner.
How can a simple solution make so big differents.
Remember the resistance may rice a bit.
But I am not sure because the draft will be a few millimeters lower. So the wetted surface increased by the lists you will get back at the waterline.
Old 12-01-2009, 05:33 AM
yuyewuyuconan yuyewuyuconan is offline
Rep: 10 Posts: 35
make another one ,become twin hull boat.
Old 12-01-2009, 11:32 PM
pistnbroke's Avatar
I try
Rep: 387 Posts: 1,269
until we see some photos of it in the water with a few sandbags on the center line and someone hanging over the side how can we tell how big the problem is ??
German Small Steel Boat Plans mtumut Boat Design 6 09-05-2009 05:51 PM
Looking for small steel barge plans BARGEASE Metal Boat Building 8 09-03-2009 12:08 PM
Pictures of steel and aluminium small crafts? Cigra Metal Boat Building 7 03-09-2005 08:33 AM
Stainless steel protection on small vessel keels Gilmarine Fiberglass and Composite Boat Building 1 02-20-2005 10:51 AM
small steel hull guest Metal Boat Building 4 09-03-2004 01:29 PM
