  #1066
Old 09-22-2010, 12:11 PM
Guillermo's Avatar
Ingeniero Naval
Rep: 2069 Posts: 3,574
Thanks fcfc.
I want to highlight this:
10. At 2120 hours (local) one person was on the helm and 2 were below. A single wave knocked the boat to 90 degrees. The boat did not immediately right, and a second wave that came quite quickly after the first wave rolled the boat to 180 degrees.
11. The boat seemed, in the words of the skipper, quite comfortable at staying inverted....
16. About 10 minutes later, the boat righted itself. The delivery skipper speculates that once the mast broke underwater, the next wave shoved the boat over enough for the keel to go to work.
I find amazing there are no commentaries at all at the "Lessons learned" about the fact that a Class 1 boat stayed inverted for 10 minutes. What about the target of 2 minutes maximum, after the lessons learned from the Fastnet '79?
  #1067
Old 09-22-2010, 03:57 PM
fg1inc
The seaworthy boat is the one that will take care of you when you can no longer take care of it.
  #1068
Old 09-22-2010, 05:15 PM
Crag Cay Crag Cay is offline
Rep: 572 Posts: 635
Abbey Sunderland's boat wasn't a Class 40.
  #1069
Old 09-23-2010, 11:05 PM
Rep: 1729 Posts: 2,464
How different ? its a similar vessel ULDB deep bulb open 40 planing design, but its rating was for Open 40, I was wondering whether it would meet class 40 anyway? It is confusing but there wouldn't be much between it would there?
That account of a class40 is revealing, 10 minutes inverted and the crew couldn't get back inside. It makes a mockery of the tests in smooth water with the crew moving weight around from inside to re-right the vessel.
Mike Johns.
  #1070
Old 09-24-2010, 04:14 AM
fcfc fcfc is offline
Rep: 359 Posts: 709
No, you make a mistake.
Class 40 edition 2010 does not need any rerighting (OSR 1 only). The boat that capsized had NO rerighting test. Note this is the first documented class 40 capsize since its existence (6 years).
Rerighting ability (OSR 0) is currently only needed for around the world race. I guess it will probably be included in future releases of the class 40 rules.
  #1071
Old 09-25-2010, 02:46 AM
Class 40 edition 2010 does not need any rerighting (OSR 1 only). The boat that capsized had NO rerighting test. ......... I guess it will probably be included in future releases of the class 40 rules.
But if you can't get back into an inverted vessel to shift water into side tanks etc then reliance on those sorts of features are not very reliable if you have to be inside to operate them. I can see if you were on deck in gear with buoyancy you'd find it hard to get back in.
Mike Johns.
  #1072
Old 10-12-2010, 10:24 PM
BATAAN's Avatar
BATAAN BATAAN is offline
Rep: 1090 Posts: 1,502
Racing has really played havoc with sensible seaworthiness in the name of speed, and winning races of course. Here's something different that's slower but gets there, and doesn't need a huge crew of testosterone. I know racing has advanced sailing theory and practice tremendously, but some things seem a silly waste of money in the pursuit of "I'm faster than you are". Fine, but do it the old way of clipper ships, set a record while carrying hundreds of tons of paying cargo and then I'll be impressed with all the engineering.
  #1073
Old 10-12-2010, 10:55 PM
Mikey Mikey is offline
Rep: 75 Posts: 368
What an excellent phrase: "Racing has really played havoc with sensible seaworthiness in the name of speed, and winning races of course"
The sad thing with it is that ordinary customers often don't understand the negative aspects - comfort also included
  #1074
Old 10-12-2010, 11:02 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
Interesting points, Bataan and Mikey.
I think it would be very interesting to see a cutting edge racing class, a la VO 70, with one additional requirement in the rules:
"The boat shall, at each port of call, take on eight thousand (for example) kilograms of locally produced cargo, to be offloaded and sold at the next port of call." If the crew want to shift the cargo around for ballast, let them- as long as they do it themselves.
Bring the old days of commerce back into it, encourage boats that can carry a load, get the fans buying trinkets and souvenirs from earlier in the race. Want a more comfortable motion in the next generation of boats? Make them carry fragile glassware and china as cargo. Could be interesting....
  #1075
Old 10-12-2010, 11:06 PM
BATAAN's Avatar
Absolutely. Thank you Marshmat. I love it. Make the designers start earning their fees by doing something a little harder.
  #1076
Old 10-13-2010, 12:03 AM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
Bataan,
Will your boat self right after being inverted?
  #1077
Old 10-13-2010, 03:58 AM
Guillermo's Avatar
Ingeniero Naval
Thanks Bataan and Marshmat for bringing in a fresh look to seaworthiness
Here a different approach:
"If you think that I am mad then you should meet my mother"
http://www.dixdesign.com/steward.htm
  #1078
Old 10-13-2010, 06:41 AM
marshmat's Avatar
A different approach, Guillermo, yes.... although not one I would care to take myself! A 19-foot trailer sailer in the open ocean is certainly a test of seamanship.
  #1079
Old 10-13-2010, 09:50 AM
BATAAN's Avatar
Originally Posted by Landlubber View Post
Bataan,
I don't know. I'll try to roll her and get back to you. The PANDORA, a SPRAY replica, was rolled and came back up with the masts gone. BERTIE has been through a great deal of bad weather and never came close. Most boats are stable when inverted, even with outside ballast. The modern racing sled with its flat sections and very wide stern seems to form a stable shape inverted. Having a very large chunk of heavy metal on the end of a fin keel certainly helps the recovery and BERTIE's ballast is all inside, so she does not have the ultimate righting force of a modern type, but can easily pack ten tons of brick or manure and deliver it on a tidal beach. Vessels are designed for different jobs.
  #1080
Old 10-13-2010, 05:28 PM
goodwilltoall goodwilltoall is offline
Rep: -48 Posts: 309
Bataan,
Please give dimesions:
SA
Displacement
Ballast
Length
Beam
Draft
Powercats seaworthiness ? fcfc Powerboats 5 04-30-2006 07:17 AM
Seaworthiness of 11' jon boat Live2Fish Boat Design 5 09-20-2005 07:55 PM
I'm reading Marchaj's 'Seaworthiness" and have a dumb question BillyDoc Boat Design 9 06-28-2005 12:51 PM
RIB Seaworthiness operator Boat Design 8 05-20-2005 07:42 AM
