| seakeeper output hi all professiond some times i think about the output format of SeaKeeper software. thats format are text and used of them was a little difficult( only a little )ok, so i try to fine some VBA code on Excell to change this format to a abular and sorted data for draw some usful graph. any body....? ![]() |
| I try to write a VBA macro for show the acceleration data from seakeeper data file: data file: 5, 5 kts; 0.00, 0 deg; wh=5 (1 Param. Bretschneider: 11.184 s, 5 m) Item m0 units RMS units Significant amplitude units 1 Modal period 11.184 s -- -- 2 Characteristic wave height 5 m -- -- 3 Spectrum type 1 Param. Bretschneider -- -- 4 Wave heading 0 deg -- -- 5 Vessel Speed 5 kts -- -- 6 Vessel displacement 834.62 m^3 -- -- 7 Vessel GMt 4.933 m -- -- 8 Vessel trim 0 deg -- -- 9 Transom method No transom terms -- -- 10 Wave force method Arbitrary wave heading -- -- 11 Added res. method Salvesen -- -- 12 Pitch gyradius 9 m -- -- 13 Roll gyradius 3.3 m -- -- 14 Wave spectrum 1.569 m^2 1.252 m 2.505 m 15 Encountered wave spectrum 1.568 m^2 1.252 m 2.505 m 16 Added resistance 145.175 kN -- -- 17 Heave motion 0.951 m^2 0.975 m 1.95 m 18 Roll motion 0 deg^2 0 deg 0 deg 19 Pitch motion 22.7 deg^2 4.76 deg 9.53 deg 20 Heave velocity 0.265 m^2/s^2 0.514 m/s 1.029 m/s 21 Roll velocity 0 (Hz)^2 0 Hz 0 Hz 22 Pitch velocity 0.00008 (Hz)^2 0.00883 Hz 0.01766 Hz 23 Heave acceleration 0.083 m^2/s^4 0.288 m/s^2 0.577 m/s^2 24 Roll acceleration 0 (Hz/s)^2 0 Hz/s 0 Hz/s) 25 Pitch acceleration 0.00004 (Hz/s)^2 0.00624 Hz/s 0.01248 Hz/s) 26 BRIDGE: Abs. vert. motion 2.366 m^2 1.538 m 3.076 m 27 BRIDGE: Rel. vert. motion 0.31 m^2 0.557 m 1.114 m 28 BRIDGE: Abs. vert. velocity 0.757 m^2/s^2 0.87 m/s 1.741 m/s 29 BRIDGE: Rel. vert. velocity 0.162 m^2/s^2 0.403 m/s 0.805 m/s 30 BRIDGE: Abs. vert. accel 0.28 m^2/s^4 0.529 m/s^2 1.058 m/s^2 31 BRIDGE: Rel. vert. accel 2.182 m^2/s^4 1.477 m/s^2 2.955 m/s^2 32 BRIDGE: Long. (due to pitch) motion 1.081 m^2 1.04 m 2.08 m 33 BRIDGE: Long. (due to pitch) velocity 0.418 m^2/s^2 0.646 m/s 1.293 m/s 34 BRIDGE: Long. (due to pitch) accel 0.186 m^2/s^4 0.431 m/s^2 0.862 m/s^2 35 BRIDGE: Lat. (due to roll) motion 0 m^2 0 m 0 m 36 BRIDGE: Lat. (due to roll) velocity 0 m^2/s^2 0 m/s 0 m/s 37 BRIDGE: Lat. (due to roll) accel 0 m^2/s^4 0 m/s^2 0 m/s^2 38 BRIDGE: MII slide; tip f/a; tip s/s 0 MII/h 0 MII/h 0 MII/h but i hav'nt the MSI data to compose the MSI curve on the Accel. Graph. any body can help me???? ![]() |
| The MSI tab in the results window can be saved as text or copied and pasted into Excel. That should let you do it. |
| Seakeeper problem! | sinper | Software | 0 | 04-20-2009 06:08 AM |
| seakeeper vs tanktest | Guest62110524 | Software | 2 | 04-01-2009 05:32 AM |
| KW output question | Delta | OnBoard Electronics & Controls | 21 | 08-10-2007 10:00 PM |
| Seakeeper Question | squivo | Software | 4 | 10-10-2006 03:54 AM |
| Combine Power output or not? | Inerested | Powerboats | 3 | 08-15-2002 02:19 PM |
