| Schooner Mainsail Area And Total C.o.e. Larson and Eliasson, in the 'Principles of Yacht Design', state that only 50% of a ketch's mizzen sail area is used to locate total center of effort. Then what about a schooner's mainsail area? And, if the mainsail is identical to the foresail in area, and is stepped aft of the midship station, is it then considered not a schooner's mainsail, but rather the mizzen of a ketch? Why doesn't David Gerr, in the 'Nature of Boats' say to only use 50% of mizzen sail area when locating total center of effort? |
| I was about to answer something yesterday, but found a bit contradicting statements in the Larsson&Eliasson.. So IMO.. Either you make the reduction of the mizzen sail area or have the Ce balanced as a ketch with greater lead compared to sloops, not both of them. What comes to schooners it's not in my knowledge.. |
| Geometric "balancing" is only useful to compare like with like, everybody has different methods and thus results (and their usefulness) vary..... Gerr illustrates one method, L&E show another, I use another method. My system is that which was used at the Davidson Laboratory of Stevens Institute of Technology, and it's outlined by Tony Marchaj in Sailing Theory and Practice(1964). This method was used at Bruce King Yacht Design for 30+ years. The DL-CE method loads the fore triangle 1.7 times the 100% area (I * J / 2) * 1.7......The mainsail (or foresail in a schooner) is taken at 1 (or 100%), and the mizzen (schooner main) at .5.......The mizzen (whatever the rig) is taken at this reduced area due to interference for spars and sails ahead of it, plus it's own mast. Using this method the DL-CE should fall somewhere between 28 and 38% of waterline length back from the stem. ![]() All that being said the CE in a schooner becomes far less critical due to more opportunities (over a typical sloop) to change the balance with sail trim.
| Thanks Ted and Tad; your info helps. Tad, 28%-38% measured from the stem not from station 0 on the waterline? |
| Sail design , area ratios of mainsail & jib ? | dale.frahm | Boat Design | 4 | 05-08-2010 05:44 PM |
| Mainsail track setup or Mainsail "V" setup? | kelldog | Multihulls | 4 | 03-25-2010 10:57 AM |
| Increasing boom length and mainsail area | Tony-Pion 30 | Sailboats | 17 | 09-11-2009 05:43 PM |
| Split Mainsail. Has this been tried before? | Omeron | Sailboats | 21 | 11-18-2007 10:27 AM |
| sail area to lateral area ratios | Ian | Boat Design | 5 | 04-07-2004 05:39 PM |
