#286
| Here you are, Antonio: NEPTUN 32 data from: http://www.caputatse.de/boot/neptun_...ekt_neptun.pdf INPUT Lh = 9,60 m Lwl = 7,50 m Bmax = 3,00 m Bwl = 2,70 m (?) Draught T = 1,60 m Body draught Tc = 0,50 m (?) Moulded depth H = 1,75 m (?) Disp = 3500 kg Ballast = 1500 kg Sail area = 40 m2 Mast height = 11 m (?) Heeling Arm = 5,04 m (?) Power = 15 KW OUTPUT Length/Beam Ratio (2Lwl + Lh)/3B = 2,73 Lwl/Bwl Ratio Lwl/Bwl = 2,78 Ballast/Disp Ratio W/Disp = 0,43 Displacement/Length Ratio D/L = 231,40 Sail Area/Disp. Ratio SA/D = 17,63 Power/ Disp. Ratio HP/D = 2,64 HP/tonne Hull speed HSPD = 6,65 Kn Velocity Ratio VR = 0,98 Capsize Safety Factor CSF = 1,99 Motion Comfort Ratio MCR = 21,12 Roll Period T = 2,18 Sec Roll Acceleration Acc = 0,15 G's Stability Index SI = 0,81 Angle of Vanishing Stability AVS = 125 º Estimated STIX = +/- 37 (to be taken with great care) Cheers. Last edited by Guillermo : 06-08-2008 at 02:36 AM. Reason: Correcting SA/D ratio |
#287
| Thanks a lot !!!!! ![]()
__________________ Be water my friend |
#288
| Antonio: Please note SA/D ratio is 17,63 Cheers. |
#289
| NEPTUN 32 INPUT Lh = 9,60 m Lwl = 7,50 m Bmax = 3,00 m Bwl = 2,70 m (?) Draught T = 1,60 m Body draught Tc = 0,50 m (?) Moulded depth H = 1,75 m (?) Disp = 3500 kg Ballast = 1500 kg Sail area = 40 m2 Mast height = 11 m (?) Heeling Arm = 5,04 m (?) Power = 15 KW OUTPUT Length/Beam Ratio (2Lwl + Lh)/3B = 2,73 Lwl/Bwl Ratio Lwl/Bwl = 2,78 Ballast/Disp Ratio W/Disp = 0,43 Displacement/Length Ratio D/L = 231,40 Sail Area/Disp. Ratio SA/D = 11,46 Power/ Disp. Ratio HP/D = 2,64 HP/ton Hull speed HSPD = 6,65 Kn Velocity Ratio VR = 0,98 Capsize Safety Factor CSF = 1,99 Motion Comfort Ratio MCR = 21,12 Roll Period T = 2,18 Sec Roll Acceleration Acc = 0,15 G's Stability Index SI = 0,81 Angle of Vanishing Stability AVS = 125 º Estimated STIX = +/- 37 PUMA 34 INPUT Lh = 10,35 m Lwl = 8,20 m Bmax = 3,35 m Bwl = 3,02 m Draught T = 1,85 m Body draught Tc = 0,63 m Moulded depth H = 1,75 m Disp = 5400 kg Ballast = 2400 kg Sail area = 55 m2 (WILD GUESS) Mast height = 15.5 m (WILD GUESS) Heeling Arm = 6.94 m (WILD GUESS) Power = 13,5 KW OUTPUT Length/Beam Ratio (2Lwl + Lh)/3B = 2,66 Lwl/Bwl Ratio Lwl/Bwl = 2,72 Length/Draught Ratio Lh/T = 5,59 Beam/Draught Ratio Bmax/T = 1,81 WL beam/Body draught Bwl/Tc = 4,79 Ballast/Disp Ratio W/Disp = 0,44 Displacement/Length Ratio D/L = 273,17 Sail Area/Disp. Ratio SA/D = 18,16 Sail Area/Wetted surface SA/WS = 2,43 Power/ Disp. Ratio HP/D = 1,54 HP/ton Hull speed HSPD = 6,95 Kn Potential Maximum Speed PMS = 7,82 Kn Velocity Ratio VR = 1,13 Best motoring speed (1.1) CSPD = 5,71 Kn Capsize Safety Factor CSF = 1,93 Motion Comfort Ratio MCR = 25,85 Roll Period T = 2,96 Sec Roll Acceleration Acc = 0,10 G's Stability Index SI = 0,88 Angle of Vanishing Stability AVS = 126 º Dellenbaugh Angle DA = 24,06 º (14 kn wind) Wind pressure coefficient WPC = 0,88 Estimated STIX 37,14 FIRST 345 INPUT Loa = 11,00 m Lh = 10,55 m Lwl = 9,08 m Bmax = 3,49 m Bwl = 3,14 m Draught T = 1,45 m Body draught Tc = 0,57 m Moulded depth H = 1,75 m Disp = 5700 kg Ballast = 2050 kg Sail area = 50,73 m2 Mast height = 15,01 m Heeling Arm = 6,58 m Power = 21 KW OUTPUTS Length/Beam Ratio (2Lwl + Lh)/3B = 2,74 Lwl/Bwl Ratio Lwl/Bwl = 2,89 Length/Draught Ratio Lh/T = 7,28 Beam/Draught Ratio Bmax/T = 2,41 WL beam/Body draught Bwl/Tc = 4,69 Ballast/Disp Ratio W/Disp = 0,36 Displacement/Length Ratio D/L = 212,37 Sail Area/Disp. Ratio SA/D = 16,16 Sail Area/Wetted surface SA/WS = 2,05 Power/ Disp. Ratio HP/D = 2,27 HP/ton Hull speed HSPD = 7,31 Kn Potential Maximum Speed PMS = 7,90 Kn Velocity Ratio VR = 1,08 Best motoring speed (1.1) CSPD = 6,00 Kn Capsize Safety Factor CSF = 1,97 Motion Comfort Ratio MCR = 24,00 Roll Period T = 2,78 Sec Roll Acceleration Acc = 0,12 G's Stability Index SI = 0,80 Angle of Vanishing Stability AVS = 120 º Dellenbaugh Angle DA = 16,13 º (14 kn wind) Wind pressure coefficient WPC = 1,31 Estimated STIX 38,68 My friend wants a safety boat for the Atlantic Crossing, but rather the smallest the better. Wich would be your choice Guillermo? ![]()
#290
| Puma 34, if in good condition. Cheers. |
#291
| I thought the same, but it seems the Neptun has an incredible and safety superstructure, unless you have another information. Both have the same STIX....
#292
| I find Neptun's MCR and SI may indicate a harsh behaviour. But you know: "Horses for courses...." Cheers. (Caution: Do not trust my estimated STIX numbers at all. Still in needing of thorough tests and development) |
#293
| [quote=Crag Cay;115082]Hi Vega, Guillermo et al. I really do mean to write something about the nature of the information that should be provided to the buying public with all new boats. I will post it in Guillermo's new thread about this. However, a couple of points you made here does illustrate the limitations of the current system. Vega here has prioritised displacement in a 'seaworthy vessel' where others might put more emphasis on something else. But by lumping all these criteria into one correct 'answer' (either Category or even STIX, etc), we must all either concur what these qualities should be, or be happy to allow other 'learned people' to prescribe an answer for us. My alternative, which I will expand on in the other thread, is to keep the information about all the qualities of the boat separate. Give the buyer details on the boat's strength, resistance to knockdown, comfort factor, weatherliness, recovery from 90 degrees, behaviour if rolled, susceptibility to crash damage, etc, etc. Then the buyer can choose where to make his own trade offs. NOW HEAR THIS! FROM THE CHIEF --- Hi guys, I've poroused over half of this thread and have to jibe in here with a layman's view. C. Cay is trying to simplify things here for the average Joe, reading boat mags and going to an occasional boat show; who is going to write a big check one day one sail away. He wants something simple to compare a few boats that look good to his eye, not techno-speak and coded engineer jargon. His concern is for performance, sure; but mostly he wants someone to assure him that his family and friends will be safe to trust him upon the sea! He wants to give his crew and guests a nice ride. That may mean quick ride to some and secure ride to others. Guillermo's comments affixed to his response to Luso in post #85 are more telling to him than the raw numbers. Go back and read it as Luso must have. HE WAS GIVEN THE FACTS WITH EXPERT INTERPRETATION. Simple and to the point!. It was Guillermo who suggested this thread to me and I probably know more about STIX already than this Joe boat shopper ever will. Something like the old "food pyramid" that gives a clear picture as to the suitability of a vessel to specific parameters might be helpful. You brainiacs need this discourse to help set classifications and regulations, but somehow before you quit this thread find a simple way to pass the information to guys like me who just want to buy the right boat. Thanks for listening,, Mark Last edited by White Knight : 11-13-2008 at 12:24 AM. Reason: Denoting who is the adressor here. |
#294
| I have felt that but didn't know why! Thanks again! |
#295
| Some comments from the peanut gallery. STIX does have some interesting features. One number that classifies marketabily, can be used to compare boats of vastly different hull form with respect to safety at sea (Guillermo has convinced me that comparing very similar boats in fine detail, as in many of the examples in this thread, is probably not its strong point), and also gives the layman an indication whether a particular design has emphasized safety (does STIX exceed boat length in feet). That's a lot to ask from one number. I think it has been very cleverly constructed. Am I wrong in thinking that this is the first widely available piece of boat data whose presentation is not controlled by the owners of the intellectual property. A precedent of a sort? (then again, how widely distributed is it?) Regarding the conveyence of this information to the public, there would appear to be some conficts of interest here. The guild nature of the profession of boat designers is a fact of life and pushing an agenda contrary to that profession's traditions and views of what constitutes its best interest is going to be hard work. Adding more independant variables to the equation would involve getting more data from designers. Adding more variables should also reduce the distribution of STIX numbers, and this in itself is an important consideration. Changing the formula for STIX in a way that improved all of its current uses would be quite an accomplishment. That said, I like the "u" suffix proposed to designate the presence of the unsinkability factor. Has anyone floated this balloon in other arenas? White Knight- Yes, the boat buyer would love to have a simple system to compare similarly priced and sized boats, but should we expect boat designers to provide the formula? Quote:
Guillermo, would you place a note in you original post that the spreadsheet has evolved. I downloaded several versions in succession as I discovered them. Thanks in advance. What is "heft ratio" (vertical distance from fridge to cupholder? ) I couldn't find this anywhere but in this thread.Have there been any studies in the distribution of STIX numbers? Has the distribution changed since the formula was enacted? Last edited by philSweet : 11-16-2008 at 01:57 PM. Reason: Changed "rule" to "formula" in last line |
#296
He wrote: "Heft ratio works like this: 20*disp. vol./(Length * Beam^2). 'Beam' is taken as the (Waterline Beam + the beam 1/8th the waterline Beam up)/2. I consider a HR of 1.0 a good compromise. I like higher numbers such as 1.5 to 2.0, but thats just my personal taste. For multis, I add the Beams of the two most leeward hulls together to figure their HR." It has the vertue of being adimensional, so you get the same figure either in metric or imperial units. Quote:
Cheers. |
#297
| Guillermo, I was thinking of a simple scattergram. Boat length on the x axis, STIX number on the y axis, and a bunch of dots representing boats in production at any given time. Wondering how much STIX scores have shifted over time. |
#298
| Phil, I don't know if somebody has worked out such scattergram and then follow up its variations with time. Not easy, as STIX is relatively new and not all boat manufacturers and/or designers make it available to the public. As a matter of fact there is a clear tendency not to inform about it. Most manufacturers just inform about the design category. Cheers. |
#299
| All of this is extremely interesting, and I really want to learn about the calculations and other things involved in the boat building/design world. Does anybody have books or litterature that I could read and study on the matter... or colleges that specify boat engineering and design? -Dan |
#300
| Dave Gerr: Boat Strength and The Nature of Boats Lars Larsson and Rolf Eliasson: Principles of Yacht Design Skene's Elements of Yacht Design Cheers. |
| stability and drop keel sailing boats | howard easton | Boat Design | 4 | 12-15-2007 04:25 AM |
| Top Three of worst sailing boats ever made! | Saf | Sailboats | 27 | 10-03-2006 08:14 PM |
| Spreadsheet for ISO STIX | Alik | Boat Design | 4 | 05-29-2005 07:01 AM |
| Sailing boats reviews | zbyszek | Open Discussion: All Things Boats & Boating | 0 | 04-04-2004 05:06 AM |
| Model sailing boats | Carl Eymnan | Sailboats | 4 | 09-05-2003 08:53 PM |
