Old 04-23-2008, 02:51 AM
Stevens47 Stevens47 is offline
Rep: 10 Posts: 11
Righting Moment
In the process of ordering a new mast for my boat. I have supplied the mast builder with the sail plans that I obtained from Sparkman & Stephens. The builder has asked me for the RM. I am going to make a call to S&S to ask what the RM is for my particular design. I have only a rudimentary understanding of RM.
My question how is RM expressed. I have seen charts giving examples of Disp lb, Hull lb, Ballast lb, Mast & Rig lb, Roll Period sec.
As a example a Cruising Mono with Disp lb=24000, Hull lb=13900, Ballast lb=9600, Mast & Rig lb=500, Roll Period sec=5.7
Static Stability=
Righting Arm ft 1.6
Max RM ft lb 38399
Heel at Max Moment deg 64.5
Would the above example be considered a example of RM that the mast builder will be looking for. If not what is the format the RM is expressed in.
Jack
Old 04-23-2008, 07:13 AM
Olav's Avatar
Olav Olav is offline
cand. arch. nav.
Rep: 337 Posts: 198
Jack,
yes, the 38400 ft-lb (RM = Displ. * GZ = 24000 lb * 1.6 ft = 38400 ft-lb) is what your mast builder wants to know.
All the best, Olav GER-1045 ____/)_/)/)___
Old 04-23-2008, 10:37 AM
Rep: 10 Posts: 11
Thank You
Many thanks Olav for the clarification.
Jack
Volvo Open 70 Heeling/Righting Moment Aly Boat Design 4 04-23-2008 05:11 AM
righting moment of a keel rapscallion Stability 4 10-17-2007 10:15 AM
Self Righting Systems kach22i Boat Design 2 02-25-2007 08:47 AM
Righting moment to aluminum tubing size? emf Multihulls 1 07-21-2006 10:23 AM
Twin Keel Righting Moment Willallison Sailboats 23 04-04-2006 01:22 AM
