| Rig Weight Reduction vs Righting Moment Assume a sailboat with displacement of 25,000 lb and RM30 of 80,000Ft Lb. If you remove 90 pounds from the rig 25' above the center of gravity what other factors to you need to know to calculate the effect on RM30? I keep hearing it would increase by 25*90 pounds but I believe it must be a bit more complex than that. |
| It is more complicated than that, there is a Sine of 30 degrees term in there also amoung other things. But for the 99.64% answer it would increase by (25*sin (30))*90 = 1125 Ft-Lbs for a "normal boat shaped" hullform. The actual answer needs the curves of form to answer.
__________________ A vessel is nothing but a bunch of opinions and compromises held together by the faith of the builders and engineers that they did it correctly. Therefor the only thing a Naval Architect has to sell is his opinion. Last edited by jehardiman : 12-08-2009 at 01:08 AM. Reason: add the normal assumption |
| Thanks. That will get me close enough. I knew the angle had to be taken into account but I was thinking the total displacement had to figure in some how. |
| It does, you just don't need it for the change in RM. The righting moment is equal to GZ*displacement; which is identical to the overturning moment - buoyant moment. By removing the weight and its associated moment, you reduced the overturning moment by some small amount, which therefor increases the righting moment. Draw yourself an FBD with the moment axis at the CG to satisify yourself. Now in removing the weight, the vessels floats new lines as it has a new displacement, and therefor will have a new GZ, but 90 lbs out of 25,000 is 0.36% so unless you have some weird hullform, just call it 1,000 FT-lbs because it is contrived calculation anyway (i.e. the real seaway will have much more effect on instant RM, which is why righting energy is the required criteria).
__________________ A vessel is nothing but a bunch of opinions and compromises held together by the faith of the builders and engineers that they did it correctly. Therefor the only thing a Naval Architect has to sell is his opinion. |
| Like I said, that's close enough. With all the stuff the first mate plans to haul aboard the numbers are just theoretical anyway. ![]() |
| Righting Moment Question - | amolitor | Boat Design | 2 | 01-14-2009 03:04 PM |
| Righting Moment | Stevens47 | Stability | 2 | 04-23-2008 09:37 AM |
| Volvo Open 70 Heeling/Righting Moment | Aly | Boat Design | 4 | 04-23-2008 04:11 AM |
| righting moment of a keel | rapscallion | Stability | 4 | 10-17-2007 09:15 AM |
| Twin Keel Righting Moment | Willallison | Sailboats | 23 | 04-04-2006 12:22 AM |
