Old 02-23-2011, 07:05 AM
Katoh Katoh is offline
Rep: 58 Posts: 196
Pod Hull Extensions
Colleges
I would like to know the theory or if there being one on bod extensions to the transom of the boat, I have a plate Aluminum boat with two of these extensions on the transom under a swim platform. The stern drive leg sits in the middle , and each pod extends aprox 1.5' aft, they are welded plate and actually carry on in the same shape as the hull lines.
It will be a while until I have this vessel in the water, so its quite difficult to actually see what these do if anything, and because I did not own the vessel prior to having these extensions put on, its hard to make a comparison between before and after.
My initial thoughts were they were for extra buoyancy in the rear, but being an I/O and a custom built vessel, I could not see why they would be needed, the other is maybe to add an extra length to the hull, or because floor line is 7" above the chine line at the transom makes for a flirty boat, could they be to add stability at rest?
Whats your thoughts.
I have a photo but don't know how to add.
Thanks
Katoh
Old 02-23-2011, 07:32 AM
anthony goodson anthony goodson is offline
Rep: 241 Posts: 391
There was a fairly comprehensive discussion on these in the boat design section last July, should be helpful.
Old 02-23-2011, 07:45 AM
Rep: 58 Posts: 196
Do you have the name of the post or a link to it? Ill like to have a read of that.
Thanks
Old 02-23-2011, 09:06 AM
Rep: 241 Posts: 391
I can't find the thread in boat design ,but if you click on my name and go to page 7 of my posts it is near the bottom. dated 28 July 2010.The thread was started by HJS and was called "extensions to a planing hull." There are a few others on this subject in boat design ,worth a troll through.
Old 02-23-2011, 04:58 PM
Rep: 58 Posts: 196
Many thanks Anthony, Was well worth the read.
The only thing nobody covered was stability at rest.
Cheers
Katoh
The post is.
Extension of a planing boat.
IOR Extensions- Flat Counter? Velsia Boat Design 12 11-19-2010 11:15 AM
New ZF pod for single installations Willallison Propulsion 7 11-04-2010 10:37 PM
Transom Pod thostorey Boat Design 4 09-04-2006 09:58 PM
HullDrag/32 revisited - invitation to propose extensions h_zwakenberg Software 0 11-05-2005 01:42 PM
Tracking & Rudder extensions - Newbie jav Powerboats 0 03-24-2004 10:40 AM
