Originally Posted by DCockey Perhaps there are two ways to look at the well. One is that the well is formed by an extension of the hull which seems to be how you're looking at it. Compared to a shorter hull without a well the well probably wouldn't cause any more ventilation of the bottom ahead of the well.
The other is that the well is cut into the hull without changing the length which is how I was looking at it. In that case the well would be a source of air for ventialation of the aft portion of the bottom.
The Simmons Sea Skiffs don't have a highly warped forefoot. Rather the deadrise looks to stay about constant forward with no warp in the bottom. The chines and keel intersect at the bottom of the stem. |
I don't see how the way we look at the boat changes anything but I agree that the propwash might ventilate the inside "sponson" in a turn but probably not running straight. I had a well boat for several years and never noticed any ventilation like that.
Yes, the deadrise does not change much forward on a Simmons. Notice though that the topsides do have serious curvature there, down low. That is what I blamed the chine riding I found in power dories on. Once she went over at speed, the suction created by the convex side held it there until power was cut and the suction dropped. If you search the C Dory owners forum you will find that others have experienced the same issue.
I think it
is an issue with power dories.
