Old 08-28-2006, 01:31 AM
Seafra's Avatar
Seafra Seafra is offline
Sailing Nerd
Rep: 16 Posts: 41
Novice Thoughts on Stability
I'm coming at this as a sailing novice but I'm trying to put together an working concept of true ocean-going stability.
Would the ideally stable monohull sailboat have a relatively small amount of beam per length(enough to maintain static stability), a steel hull to increase it's displacement, a fiberglass/composite cabin construction to keep the COG low, and a shallow draft twin keel(in a 90 degree split at the beam), tall narrow fuel tank on port, and tall narrow freshwater on starboard. From what I can tell, this should result in a vessel with great dynamic roll stability but relatively poor handling characteristics
Talking about keels can be like talking about religion I'm sure- but the twin keel seems to offer some good advantages from a cruising aspect though I can't image a racer much appreciating the extra wetted surface. My only hangup is that a twin keel gives me the sense that once a boat has turtled it would contribute to it's inverted stability rather than self right. I very easily could be wrong though.
Also, could someone please attach a pic of a bilge keel so I can figure out what it is? Is it synonymous with full keel designs?
More questions to come....
Old 08-28-2006, 07:58 PM
GregW GregW is offline
Rep: 10 Posts: 3
For a short discussion on bilge keels go here:http://www.boatbuilding.com/article....gesoftwinkeels
Old 08-29-2006, 05:34 AM
Rep: 1729 Posts: 2,464
Seafra
You might like to read much of what we discussed here:
http://boatdesign.net/forums/showthr...ight=twin+keel
Cheers
Mike Johns.
Old 08-29-2006, 08:27 AM
Seafra's Avatar
Sailing Nerd
Rep: 16 Posts: 41
Thanks for the articles, guys. Great reading all around.
Twin keels seem to offer great advantages at the cost of tank time. It seems that anyone could throw on a twin keel system and call it a day- but to have a design that gives you the fluid advantages in relation to hull speed and handling...that's where the art/science hybrid comes in.
It's interesting how little thought the idea geats on this side of the pond.
Old 04-02-2007, 10:17 AM
knowme knowme is offline
Rep: 10 Posts: 7
Thanx for the articles. I was wondering if there were any hydrostatics excel sheet available in this forum.
some thoughts... rotorhead Boat Design 0 08-17-2006 06:09 AM
rebuilding novice huntermike32 Boatbuilding 4 03-19-2006 04:43 PM
Submarines for a crazy novice Lecter Boat Design 12 09-13-2005 09:56 AM
Novice to Boat Building Jerry_Lincoln Fiberglass and Composite Boat Building 5 03-27-2005 05:16 PM
novice rudder question floatsinksunk Boat Design 5 02-05-2004 01:50 PM
