Old 09-25-2006, 08:35 PM
OldYachtie's Avatar
OldYachtie OldYachtie is offline
Rep: 10 Posts: 56
New stability requirements for catamarans
The coast guard wants passenger sailing catamarans to satisfy the following:
(b) A sailing vessel that operates on partially protected or exposed waters must be designed to satisfy the following equation:
Where—
B=the distance between hull centerlines in meters (feet).
As=the maximum sail area in square meters (square feet).
Hc=the height of the center of effort of the sail area above the deck, in meters (feet).
W=the total displacement of the vessel, in kilograms (pounds).
X=7.32 kilograms/square meter (1.5 pounds/square foot).
[CGD 79–023, 48 FR 51017, Nov. 4, 1983, as amended by CGD 83–005, 51 FR 924, Jan. 9, 1986; CGD 85–080, 61 FR 944, Jan. 10, 1996]
I can work this, as it isn't complicated, but what the heck is the outcome measuring? Apparently it's too obvious to mention. Except it's not obvious to me.
Old 09-25-2006, 10:36 PM
OldYachtie's Avatar
Rep: 10 Posts: 56
And here's the equation, which goes with the definition (was in a .gif and so didn't cut and paste
0.1(W)B / (As) (Hc) is greater than or equal to X
Old 09-26-2006, 04:46 AM
Vega's Avatar
Vega Vega is offline
Rep: 132 Posts: 1,606
The stability of the boat, considering its sail area?
This apply only to commercial boats?
Old 09-26-2006, 10:10 AM
Rep: 1758 Posts: 1,561
What they are measuring is the average ability to resist the moment of the wind pressure on the sail. But is seems a little low, that load would be reached at ~8m/sec stagnation pressure.
Old 09-26-2006, 01:04 PM
OldYachtie's Avatar
Rep: 10 Posts: 56
Yes, only commercial boats that carry paying passengers. The thing that puzzles me is that the equation contains the elements of stability, beam and displacement, and the elements of capsizing moment, sail area and mast height. So, why should the solution be anything but a coeffecient? Why would it be an outcome of force per area of something, and yes, why such a small number?
Old 10-14-2006, 11:31 AM
taniwha's Avatar
taniwha taniwha is offline
Rep: 44 Posts: 95
MCA / CE and other regulations apply the International Standard ISO 12217-2 stability of sailing yachts above 6m including requirements for multihulls.
Computer Requirements for Boat Design Konaphil General Computing 19 09-25-2008 08:33 AM
Freeboard requirements Alik Boat Design 1 05-07-2005 09:38 PM
Catamarans: 2004 Sales Report for New and Used Catamarans catamarans Press Releases 2 08-04-2004 11:24 AM
Catamarans: 2004 Sales Report for New and Used Catamarans catamarans Press Releases 1 06-10-2004 03:53 PM
Specific Math Requirements JFine Education 2 08-08-2003 06:31 PM
