Old 10-31-2007, 04:26 AM
saeedeh saeedeh is offline
naval architecture
Rep: 10 Posts: 13
natural ferequency
hi guys
how can I calculate ang get some info. about natural ferequency of planning boat?
is it important item in design?after that I want to compare it with frequency of porpoising? is there any similar study?
thanks before
Old 10-31-2007, 09:52 AM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1930 Posts: 4,195
As far as I know if your boat porpoises the motor trim angle is incorrect
Regards
Fanie
Water ! Just gimme water !
Old 10-31-2007, 11:08 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1514 Posts: 5,518
Trim will sometimes correct it bit is not neccesarily the reason for it.
Old 11-05-2007, 08:57 PM
powerabout powerabout is offline
Rep: 432 Posts: 1,358
saeedeh
The 2 are not related, it a force-drag-lift issue ( and hence speed related)and as the guys say trim can fix it more often on slow boats less often on faster boats say 50kts and over being fast.
A boat that performs best in a slight chop may well porpoise in dead flat conditions.( drag goes up)
Quite often a longitudinal weight transfer can also stop it. ( angle of attack change)
Different styles of propellors can also stop or create porpoising, due to their bow or transom lifting properties.
If your talking a shaft driven boat you lose the ability to alter drive trim but weight and prop are still avaliable.
Cheers
Powerabout
(newbie)
Old 11-06-2007, 07:14 AM
Previous Member
Rep: 0 Posts: 0
Originally Posted by saeedeh View Post
hi guys
thanks before
This planing hull calculator will indicate if the boat has a tendency to porpoise:
http://illustrations.marin.ntnu.no/h...ing/index.html
It is a function of many factors. Speed and longitudinal location of CoG are important factors. Moving weight forward does indeed reduce the tendency.
Rick W.
natural period(Tn) and yacht motion urisvan Stability 21 03-14-2007 10:45 PM
