Old 08-03-2010, 10:37 PM
freeboatrsrce freeboatrsrce is offline
Rep: 10 Posts: 20
Maximum Load on the Gunwhale?
Hello, I would like to figure the amount a boat will heel (in degrees) when a given load is placed on the gunwhale. This is for a small boat, of 340 pounds displacement. From the cross curves of stability, calculations show the boat will have a GZ of 1.54 feet at 36 degrees of heel for a righting moment of about 523 ft-lb. At 36 degrees the gunwhale is at the waterline. Is it safe to say that you can place up to 340 pounds on the gunwhale without the shear line falling below the waterline?
Wayne
www.freeboatresources.com
Solar Maximum JonathanCole Boat Design 40 05-11-2012 05:14 PM
Maximum trailerable towing width Saylaman Multihulls 28 03-03-2011 09:25 AM
Maximum Capacity Calculations Willallison Class Societies 11 06-22-2010 04:55 PM
What is the maximum deadrise angle? jfblouin Boat Design 3 09-20-2004 07:36 AM
Maximum beam ? Slowmo Sailboats 48 09-01-2004 01:03 PM
