| Looking for some more stability advice from you clever people I have posted a couple of times for some help on here already and have got some good advice. Im basically redesigning a ro-ro ferry to comply with regulation 12a. I have currently removed 300 tonnes of fuel and replaced this with a double hull under the six fuel tanks. The total added steel was approx 50 tonnes. From this I have worked out the ships new deadweight, lightship and draft however im not sure how to go about proving the ship is still stable. I have all the parent ships data and have done been taught a bit of nav arc before Im just getting abit confused from having to work backwards from the fugures I have. im assuming I will have to calculate the fuel tanks new centres LCGs and the free surface effect etc but Im not sure what else. as always thanks for any advice James |
| Can you add ballast to equal the fuel you removed?
__________________ Gonzo |
| James Do you have the stability booklet?..ie do you have the cross curves of stability? |
| cheers for your replies guys, Gonzo, I have been told to try keep away from simply adding ballast to replace the fuel. Ad hoc I have the statical stabilty curves of each load condition but obviously these conditions have now changed slightly, is this what you are talking about? |
From the curves of stability, you can calculate the stability using the KN data, at the new displacement and LCG, VCG. |
| Small boat-like device stability ( not for people ) | cs2870 | Boat Design | 8 | 04-01-2011 08:16 PM |
| Some people should not own boats! | BHOFM | Open Discussion: All Things Boats & Boating | 34 | 07-03-2009 10:56 PM |
| and some people just do not learn.... | Wynand N | Open Discussion: All Things Boats & Boating | 11 | 12-02-2007 10:22 AM |
| What do people want in a boat? | Bertram | Boat Design | 5 | 09-15-2006 07:07 PM |
| Whats going on people | Littlebearcanoe | Boat Design | 2 | 09-07-2005 07:06 PM |
