She's a large radius bilge with a moderate fin and skeg hung rudder and I've stretched her as described previously except for one calculation mistake on my part, the displacement is now 46500 Lbs., ballast of 16000 Lbs. The draft of 6' is a bit shallow for this and so I'm including a 3/4" thick 14" wide horizontal fin plate on the bottom of the keel; its just the width of the fin at the leading edge, then it gets wider gradually as you go aft until the maximum width of 7" per side is reached (about 45% aft), and then it stays that width going back. The mast is now 72' tall above the rail (76' 6" to LWL) and on center 20' 5" from the bow. Foretriangle length 20'5", luff 72', 735 sf Mainsail: foot is 20'3", luff 64'9", 655 sf So the total square feet is 1390 and the S.A./Displ is 17.2 A 130% Genoa will give me 935 sf and for a total of 1590 sf with the main and 19.67 S.A./Displ. The Staysail will be 350 sf. The required moments of inertia of the mast will be: Itt 46 ins^4, Ill 114 ins^4. That is based on a removable forestay and the Ill would reduce quite a bit if the forestay was fixed. However, I am considering a fixed forestay. All shrouds, headstays and back stay are 3/8" 1 x 19 type 304 wire. The backstay is split near the base to be two 5/16" 1 x 19. The upper part of the stay can then be insulated and used as a radio antenna. Both 3/8" and 5/16" wire use 5/8" turnbuckles. I plan to use a small 60 sf backstay at night when moored to keep her pointed into the wind. I hope this helps, if you need anything else, let me know and I'll get it. Thanks for the help--I'm surprised at how much work in involved in good rudder design. By the way, I don't have to have someone do the work for me, I just don't know what the formulas are that help me to determine with the optimal size of the rudder should be, so even a formula is appreciated. |
| The Design Spiral, or where to start building a boat. | apex1 | Boat Design | 26 | 08-30-2010 11:02 PM |
| Outboard rudder vs. inboard rudder | designdreamin | Boat Design | 0 | 06-27-2006 10:05 PM |
| Rudder Angle And Effective Size Of Rudder... | saildog | Sailboats | 5 | 03-06-2006 03:34 PM |
| rudder | rodbiser | Services & Employment | 1 | 06-10-2004 10:08 PM |
| New Rudder verses Old Rudder | Cliff Ruckstuhl | Sailboats | 0 | 03-06-2004 03:36 PM |
