Old 03-25-2009, 11:27 AM
amateur mariner amateur mariner is offline
Rep: 30 Posts: 44
Location of GM Transvers
Hi,
I want to ask two questions
1 Is there any periodicity for Inclining experiment?
2 What is the analysis if GM transvers is slightly starboard or port of center line?
Cheers
Old 03-25-2009, 07:21 PM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 1776 Posts: 2,692
1. do you mean period as in roll period, or period as in time between having to perform an Inc. Expt?
2. Is the TCG creating 0.0001 degrees list or 0.1, 1, 10 or 20 degrees???
Old 03-26-2009, 09:50 AM
Rep: 30 Posts: 44
1. I mean periodicity of Incl. Expt.
2. I want to know that if i get to know that my GM transverse is slightly stbd or port of centerline, what all affects it has?
Old 03-26-2009, 10:19 AM
Naval Architect
1. If the boat has changed from its "launched" as delivered state. If the mass has increased and/or move items around on board which affect the GM, then you need to re do it.
2. You can only tell, once you have performed the calc's what the effect is, and then ascertain if it is a problem.
Old 03-26-2009, 01:15 PM
Rep: 30 Posts: 44
I have come to know that my Transverse GM is Port?How can I say it is a problem or not?What I should do to come to a conclusion?
Old 03-26-2009, 04:57 PM
DavidJ DavidJ is offline
Rep: 325 Posts: 125
Transverse GM, despite what it sounds like, is actually a vertical dimension and cannot by definition be to port. You are referring to TCG or "transverse centre of gravity" like Ad hoc said and it is only a problem if it produces a noticeable list. Many boats launch with a slight list. Is this boat still in design stages or is it on the water? If you are already using it and you can't notice the list then I would guess that it is not a problem.
You will only need to do a new inclining experiment if like Ad Hoc said there has been major changes in weight or location of weight.
Old 03-26-2009, 05:14 PM
DEboater DEboater is offline
Naval Architect Student
Rep: 10 Posts: 15
If you do the calculations and find out your TCG is not 0, and you think you may have transverse stability issues then you have to run through the appropriate stability criteria for your vessel to see if it has appropriate righting arm with statical stability curves. Use imo/CG/ABS/etc criteria.
Old 04-05-2009, 03:49 AM
Guillermo's Avatar
Ingeniero Naval
Rep: 2041 Posts: 3,567
Depending on each country regulations, some fishing vessels, houseboats and other floating structures are to be checked for adequate stability at 5 to 10 years intervals.
Cheers.
Guillermo Gefaell
Moon Yacht Design
Location of VCG/KG colinstone Stability 42 08-24-2009 10:43 PM
location of bulkheads rkpshenoy Multihulls 9 06-16-2007 03:36 PM
Exhaust location Allan Jennings Metal Boat Building 6 02-08-2006 01:30 PM
Prop Location bsmit24 Propulsion 20 04-20-2005 10:43 PM
Mast location coyotee_ken Sailboats 8 10-25-2002 12:32 PM
