| Linking metacentric height to drive force Hello, Does anybody know of an empirical formula linking the metacentric height (KMT)to drive force on a sailing yacht? i.e. If I increase my kmt by 1%, how much do I increase my drive force for a given angle of heel assuming a modern sailplan? Thanks J |
| It doesn't quite work like that. Initial stability isn't really very meaningful on a yacht hull, unless it is very beamy or a catamaran. Most monohull yachts operate at high (20 to 30 degree) angles of heel. Here the keel makes a significant difference, as does the section shape near the deck. You can legitimately relate driving force to side force for a certain apparent wind angle. Performance prediction (which you are getting towards) is not totally straight-forward. Potentially, if you have a real (or estimated) GZ curve then you could link heel angle to sail side force, and infer an approximate driving force, which you could use to estimate a vessel speed. Hope this helps. Tim B.
| It's indicative, not accurate! My point was that initial stability calcs don't really apply in this region. Tim B.
| Up to 30 degrees...approximately: Righting arm GZ = GM * sin(f) * cos(f) Righting moment RM = m * g * GZ Heeling moment HM = F * HCE In equlibrium RM = HM, so Sail Force F = m * g * GM * sin(f) * cos(f) / HCE, where m = mass of sailboat g = acceleration of gravity GM = metacentric high between center of gravity and metacentre f = heel angle HCE = distance between sail centre and underwater lateral centre ...or not?
__________________ Only shared knowledge can grow. |
Tim B is correct, GM is irrelevent for sail carrying equations. The above analysis (when GZ is correct) is only true when f == 0 (i.e. zero heeling force) AND the hull is wall sided, always a very poor assumption for most sailing vessels. Basicaly, the heeling moment must be balanced by the actual righting arm at f, not GZ=GM sin (f), the apparent righting arm.
__________________ A vessel is nothing but a bunch of opinions and compromises held together by the faith of the builders and engineers that they did it correctly. Therefor the only thing a Naval Architect has to sell is his opinion. Last edited by jehardiman : 05-03-2010 at 01:55 PM. Reason: typo |
| Well, jehardiman, could you then explain this. The first picture is a quite normal modern sailboat hull. The other is her righting arm curve both calculated as above (purple) and calculated by hydrostatic software (blue). Can't see any significant difference up to 30 degrees.
While it is close, it is not the same, and it only works for that limited hull form; a CCA hull or a skimming dish wouldn't have a RM curve like that. Theirs would be much different in 10-30 degree range the due to form stability differences.
__________________ A vessel is nothing but a bunch of opinions and compromises held together by the faith of the builders and engineers that they did it correctly. Therefor the only thing a Naval Architect has to sell is his opinion. |
| Never said the same, reed my first post ...approximately. Still some examples:
| No, I kenned what I read. FWIW, you still haven't shown any different hullforms, all those you show are effectvely equivalent. All I see that you did was manipulate the hardness of the turn of the bilge below the 30 degree heel waterline, which has no effect on Ixx or TCB other than trigometrically with heel. Change the flare, the flam, the depth, and the height of the turn of the bilge. To see the true effect do a scow, a cylinder, and a plank-on edge hull.
| It is a good enough assumption that most modern monohull will have a constant RM (Nm/deg) at normal sailing angles in static conditions. However in dynamic conditions RM will be easily 10% or more lower due to wave pattern. Forgetting this will often be a bigger error. |
| Jeridiman, You really think that cylinder or plank-on-edge sailboat hulls are common?
It is important to remember that many of the people who come to this forum to ask questions are not in marine professions or avocations, and often do not know the question they need to ask. Tossing off a limited case rule of thumb use only in the preliminary design of a particular hull form without defining the boundaries is not only unprofessional, but disingenuous and potentially harmful to the op. Tim B answered the op's question correctly, there is no single formula, empirical or otherwise, that correctly links KM to driving force. Even the rule of thumb you give does not link to KM, it uses GM, which was not part of the original question. Without knowning more about the actual situation with generated the original question, it is improper not to give the absolutely correct answer. Once you have given that, then you can ask, as I usually do at work,"Why do you want to know that?" Which will lead to a discussion which reveals that the actual question that needs to be answered is different than the first one posed.
| Metacentric height is always 24/12, or so. | apex1 | Open Discussion: All Things Boats & Boating | 76 | 02-12-2010 04:48 PM |
| Metacentric Height | Paul Jones | Stability | 39 | 09-11-2009 05:18 AM |
| metacentric height | BennyWailer | Stability | 8 | 04-03-2007 03:13 PM |
| Metacentric Height - FREE!Ship or Michlet | Guest625101138 | Stability | 5 | 01-22-2007 02:52 AM |
| Metacentric Height | Biomechanist | Boat Design | 6 | 09-23-2005 03:05 AM |
