| The same way it was calculated before the compartment was flooded.
The LCF is the line about which the ship trims when a weight is moved on the vessel. It is found using the first longitudinal moment of area (i.e. the intergral over the area of {x dx dy}) so that the displacement stays the same for small angles of trim.
For the damaged case like you have, you must first sink and trim the ship before you can calculate the new LCF. Are they looking for an exact answer or is this a mythical "rectangular barge"?
Edit; Just to note, the area is the effective waterplane, so the damaged compartment is excluded.
