| Large Stability Calculation help!! (2) |
| when cheel the ship's vcb>vcb0 ,so vcb in this table is distance from B to ro 10deg base line ? |
| Calculation of righting lever: For cross-curves based on KG=0, called KN curves: GZ (righting lever)= KN - KG*sin(heel) where in this case: KN = PN KG = KMT The draught is calculated based on the load case. Based on the load case a certain trim and displacement can be calculated using the hydrostatic tables. Based on this data the appropriate cross curves are selected for calculation of the stability curve. google cross curves or kn curves for more information. |
| thank you !IT is not easy to make a stability software. |
| well that's why others do it.... |
| Large Stability Calculation help!! | Crodriguez | Stability | 14 | 04-05-2012 12:11 PM |
| Stability Calculation Software - Catamaran | APP | Stability | 0 | 10-15-2011 05:22 AM |
| stability calculation formula | hbr | Stability | 10 | 08-12-2011 08:19 AM |
| Stability Calculation of Ropax | eng.naval | Stability | 10 | 05-13-2009 08:39 PM |
| stability calculation | Tim_Hastie | Boat Design | 1 | 06-14-2004 04:42 PM |
