| Initial Stability Calculation Error in Freeship I was setting the shape of my boat's hull in Freeship v2.6, a catamaran by the way, and I realized my initial longitudinal stability (KMl) was negative while my transverse stability was ok. So I opened the design hydrostatics and saw the that the longitudinal waterline inertia was also negative, thus making my KMl negative. Is this a known issue for cats in this Freeship version? |
| Hi Ricardo, Yes, this is a common problem when modelling a catamaran in Freeship. I haven't found any way around it- although, to be fair, I have neither the coding skill or the time to go into the source code and find the problem. For cats, I usually work with only one hull in Freeship, then turn it into a cat in something else- usually Rhino.
| Thanks Matt. Do you know if DelftShip calculates it any better? |
| stability calculation formula | hbr | Stability | 10 | 08-12-2011 08:19 AM |
| Freeship Discussion Regarding Cross Curves Calculation | EAP | Software | 8 | 06-10-2010 04:44 AM |
| effects of waves on ship stability calculation | janelove | Stability | 11 | 04-29-2008 04:44 PM |
| stability calculation | Tim_Hastie | Boat Design | 1 | 06-14-2004 04:42 PM |
| Stability calculation sample from actually ship -tug boat...etc | fadly2000 | Services & Employment | 3 | 05-22-2004 09:12 AM |
