| Inclining Experiment: a more simple way I was searching for a simplest way to do an Inclining Experiment on small vessels and (roughly?) determining KG. I came to this simple deduction, and wish to know if this is right. If right, this can be easily inverted to get Heeling Angle for a given excentric weight, having KM, KG, and Disp. as data (I suspect it's not correct as it's too simple and I couldn't find something similar on many stability books). Comments will be appreciated... |
| Attached is a little spreadsheet using formulas from previous post. I'll appreciate if someone could compare outputs with some Inclination Experiment taken on real life. I wonder if it's accurate-enough for small vessels like sailboats, kayaks etc. Again, comments will be appreciated... ![]() Thanks |
| Thanks Paul, your formula is what I've seen on stability books, I will add it to the spreadsheet. What I thought is than when a small boat return to equilibrium, weight's movement line is no longer parallel to waterline, assuming that load comes from center deck. Also, I guess where the center of load's moment should be located: just from where it comes, or the vertical line passing CB and CG? Your designs are cool, by the way ![]() |
| Attached is a spreadsheet having this simplified Inclining Experiment. And two images showing two different metods that produce exactly the same results. One of them uses tg(heeling) and G moves to G' over a line parallel to deck (the standard formula). The other uses sin(heeling) and cos(heeling) to correct Weight moment. In this second case, G moves to G' over a line wich is perpendicular to B'M. In reality, G moves to his new position G' over the stright line GW, wich is not parallel to deck nor perpendicular to B'M. I wonder if this produces a significant error ![]() |
| inclining experiment | scotsman | Motorsailers | 21 | 06-18-2011 01:56 PM |
| Inclining Experiment.... | Sunny.K | Stability | 47 | 04-21-2009 04:17 AM |
| Inclining Experiment | mbhanoo | Boat Design | 3 | 04-02-2009 07:12 AM |
| Caculating data from inclining test | toda | Software | 4 | 08-24-2008 11:35 PM |
| need help -- inclining experiment calculation | jerryah | Boat Design | 8 | 12-02-2005 07:47 PM |
