Old 02-08-2009, 05:18 PM
Sunny.K Sunny.K is offline
Sunny.K
Rep: 10 Posts: 10
Inclining Experiment....
Can someone help me with this inclining Experiment??
If I'm to conduct an incline experiment on a double hull boat of like 39meters and a displacement of like 445tonnes but there was new renovations to the boat.....
I need to know where I could find informations on how to perform the experiment or someone can help me. I understand using pendulum and weights but how and where should I have to drop it from is what i need (whether bridge deck, main deck etc) and what actually should I do?? please if someone can help it would be much appreciated??
Regards,
Sunny
Old 02-08-2009, 06:24 PM
Guillermo's Avatar
Ingeniero Naval
Rep: 2041 Posts: 3,567
Read Annex A in this document:
http://www.nmsc.gov.au/documents/NSCV/PART6C.pdf
(Well, as a matter of fact, read all the document)
Cheers.
Guillermo Gefaell
Moon Yacht Design
Old 02-08-2009, 08:49 PM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 1776 Posts: 2,692
It worries me that if you are performing an inclining expt yet do not seem to know the basics. Are you a qualified naval architect?
Old 02-08-2009, 09:38 PM
Sunny.K
Rep: 10 Posts: 10
This experiment is gonna be done by a Naval Architect...this is for my own learning purposes!! so when the experiment is done I would already have a clue....I wanna learn every operations that is happening in this shipping company in PNG....like I said before I am engineering graduate of other discipline but wants to shift into marine and naval so I could study it and continue on to uni with it........
Old 02-08-2009, 09:47 PM
Naval Architect
If another Naval Architect is doing it and are you with him? why not ask the naval architect....this is the most obvious route!
Not being picky here, but if you have "one to hand"...it is the most logical person to ask...and they can explain to you in real time not bitty by email
Old 02-08-2009, 10:26 PM
Sunny.K
Rep: 10 Posts: 10
true...
Old 02-08-2009, 10:27 PM
Sunny.K
Rep: 10 Posts: 10
but it is always good to have your own info and researches!!!
Old 02-08-2009, 11:06 PM
Naval Architect
Guillermo gave you that already....
Old 02-09-2009, 12:22 AM
Ike's Avatar
Ike Ike is offline
Rep: 1256 Posts: 1,317
if you simply google inclining experiment you will find lots of references
Ike
New Boatbuilders Home Page
Boat Builder News Blog
My Boating Safety Blog
Old 02-09-2009, 02:21 PM
Sunny.K
Rep: 10 Posts: 10
what if I can't be bother reading alot of ********...to get the right thing you need the place!!!
Old 02-09-2009, 04:12 PM
Joakim Joakim is online now
Rep: 307 Posts: 400
How typical is it to use a digital inclinometer? What is the reason for not allowing it to be the only tool used? With current technology and some care a digital inclinometer can be at least as accurate as a pendulum and is not affected by wind and the skill of the person reading the pendulum.
I have designed and made some digital inclinometers, which have an accuracy of 0.5% (of angle difference) +- 0.01 degrees and a resolution of 0.001 degrees.
Joakim
Old 02-09-2009, 05:02 PM
Guillermo's Avatar
Ingeniero Naval
Digital clinometers are only good if the vessel doesn't roll at all when at the inclining experiment, unless they have means to promediate readings, as it is very difficult to do that by 'eye'.
Most inclining experiments are performed in waters that are not perfectly flat (sea is not a pool) and so the vessels always move slightly, making the digital clinometer to show constantly varying measurements difficult to 'catch' if they are not provided with the adequate software. Those are easier to estimate when using pendulums, although some practice is required.
I use one or two pendulums, depending on the length of the vessels, promediating 10 pairs of deviations for each weight movement. If conditions are good enough, I also use a digital clinometer only to cross-check results after we calculate the angles from the pendulums readings.
Pendulums are great if conditions are not perfect (which happens most of the times). They are also cheap...
Cheers.
Guillermo Gefaell
Moon Yacht Design
Old 02-09-2009, 06:12 PM
Naval Architect
Using the digital inclinometer is also bit of an over kill. Considering everything else is "rough". For example, how accurately can you read the draught marks??..look at the systematic percentage errors of this whole procedure and you'll see the displacement can vary considerably.
The more accurate you try, the less accurate the answer. A series of good rough estimates are far better than one single attempt at an accurate answer. I would never believe an answer of 0.001 degree too
Old 02-10-2009, 02:03 AM
Guillermo's Avatar
Ingeniero Naval
Totally agree.
For very small commercial fishing boats, where it is imposssible to mount a pendulum, we use a simple air bubble clinometer, with precision of only 0.5 deg. That's enough precision when you're measuring 14º tilts, as the 1964 spanish norm asks for (not to reach that angle, nor submerge the sheerline, using some heavy test weights).
Cheers.
Guillermo Gefaell
Moon Yacht Design
Old 02-10-2009, 02:47 AM
Rep: 307 Posts: 400
Cheers.
Yes, of course an appropriate software is required. My inclinometer records the angle 10 times in a second for one minute (600 samples), draws a curve, calculates an average and error estimates for the average for each of the 9 measurements for the standard test.
I actually think just the opposite. A digital inclinometer is better when the conditions are not perfect. I have done some comparisons of an experienced pendulum user vs. my inclinometer. In perfect conditions the results are just the same, but in rough ones a much better linearity was achieved with the inclinometer.
Pendulums are cheap, but requires more space and work, especially when you are required to have several of them. Which digital inclinometer are you using? How much did it cost?
Ad Hoc:
As I said, the accuracy is not 0,001, which is the resolution. Thus you can distinguish an angle difference of a 0,001 (e.g. putting a single A4 sheet under one end of a 5 m bar), but neither of the angles are 0,001 accurate.
For the actual on water measurement in good conditions you will get repeated measurements to +-0.01 degrees from each other. The conditions need to VERY bad in order not to achieve +-0,1 degrees. That would need rolling of several degrees and actually wind is much worse than waves, since wind can cause a shift in the average, especially for sailboats.
Joakim
PROCYON project........a Bold experiment brian eiland Sailboats 67 09-09-2011 11:25 AM
Caculating data from inclining test toda Software 4 08-25-2008 12:35 AM
An Interesting Science Fair Experiment Earl Boebert Boat Design 10 05-21-2007 04:38 AM
Nedd help with ASTM for USCG inclining exp on T boat capn-jer Software 2 03-30-2006 09:40 PM
need help -- inclining experiment calculation jerryah Boat Design 8 12-02-2005 08:47 PM
