Old 09-16-2011, 08:52 PM
iamseaman iamseaman is offline
Rep: 10 Posts: 2
I need your assistance to clarification about stability criteria as per IMO reg.
Dear All Members,
I need your assistance to clarification about stability criteria as per IMO regulation
For now we have pontoon barge as follow,
L.O.A : 37.6 M.
WIDTH : 8.0 M.
DEPTH : 0.76 M.
LIGHT LOAD DRAFT : 0.23 M.
MAX DRAFT : 0.57 M.
I need to load cargo on this pontoon and also I need to satisfy about the stability criteria as per IMO regulation, I will use RESOLUTION A.749(18) for this issue.
Could you please help me to clarification about the RESOLUTION A.749(18) Adopted on 4 November 1993 (Agenda item 11)
CODE ON INTACT STABILITY FOR ALL TYPES OF SHIPS COVERED BY IMO INSTRUMENTS,
What the Chapter can I use to applicable about the stability criteria for this pontoon barge? Chapter 3 , 3.1.2.1 to 3.1.2.4 or Chapter 4, 4.7.3.1 to 4, 4.7.3.3 ??
Please advise,
Thank you in advance for your kind assistance,
Old 09-19-2011, 09:42 PM
Vinassman Vinassman is offline
Rep: 10 Posts: 28
Hi Iamseaman,
As per Intact Stability Code (formerly resolution A.749(18)), "chapter 4, 7.1 Application", this part applies to pontoon if you meet the following requirement:
- non self-propelled (should be the case)
- unmanned (same)
- carrying only deck cargo (same)
- having a block coefficient of 0.9 or greater (should be ok)
- having a breadth/depth ratio of greater than 3 (10.5 in your case)
- having no hatchways in the deck except small manholes closed with gasketed covers (should be the case).
If you meet this requirement, then you shall comply with the criteria from 4.7.
Hope it will clarify.
VM
Old 09-21-2011, 01:07 AM
Rep: 10 Posts: 2
Thank you very much Vinassman.
Stability Criteria stalin Stability 4 06-01-2010 12:12 PM
intact stability criteria for tug Agusta Stability 1 04-05-2009 09:37 PM
Heavy Lifting Stability Criteria Guest-3-12-09-9-21 Stability 17 08-05-2008 01:18 PM
Immediate help for stability criteria choice alpamis34 Boat Design 1 03-25-2007 01:45 AM
