Old 01-31-2010, 05:19 PM
christoph christoph is offline
Rep: 10 Posts: 2
How much weight can my pontoons hold at half emersion?
I have a calculation that I need answered by you guys.
I have 3 pontoons that are 33 feet long with a 24 inch diameter. How much weight will these pontoons hold at half emersion in fresh water? The pontoons are aluminium.
If some one could post the actual equation that would be awsome to! I have found no place on the net that has this equation.
Thanks for the help
Old 01-31-2010, 06:14 PM
sharpii2 sharpii2 is offline
Rep: 471 Posts: 954
Thanks for the help
What you are really asking for is the displacement at the half diameter.
I'll assume the pontoons are not just straight tubes with a flat bulkhead at the ends.
You need a separate calculation for the ends which is based on their shapes.
For the straight tube portion, the formula is:
(Diameter in ft squared)*0.785*Length*Number of pontoons*62.2 pounds/2
This will give you the displacement of just the straight sections at half diameter immersion. The weight of the pontoons must be subtracted from this to give you the weight they will actually support.
I am highly suspicious of the terms 'perfect' and 'best'. I favor the terms 'inadequate', 'adequate', and 'better', instead, with the first of these closest to being an absolute.
Old 01-31-2010, 06:37 PM
Rep: 10 Posts: 2
is this correct?
Thanks for the quick reply .I do have some questions though. I was looking on a web site called u-fab pontoons and according to there spread sheet it says that a pontoon of 24 inch diameter at 30 foot long will hold 5500 lbs . why is this so different than the calculation that you gave me?
Old 01-31-2010, 08:18 PM
Rep: 471 Posts: 954
It looks like they are either loading the pontoon down to almost all its diameter or they are assuming you are actually using two, as most pontoon boats do, and using the full volume of one to calculate the half volume of two.
3.14*30*62.4=5878
which is pretty close to what you got on their spread sheet. They may have allowed for the lesser displacement per foot of the ends.
Old 01-31-2010, 09:20 PM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
Each cubic foot equals 62.4 pounds of water.
You can figure out the rest.
-Tom
Old 02-01-2010, 12:38 AM
pistnbroke's Avatar
I try
Rep: 387 Posts: 1,269
feet inches pounds ...god help america
Old 02-02-2010, 12:53 PM
Mariner
I get ~8500 pounds of buoyancy half submerged. That's assuming tapered or rounded ends and circular cross-section.
Your total vessel weight should not exceed ~6000 pounds as this is the total buoyancy available from one pontoon.
-Tom
Old 02-03-2010, 12:53 AM
Mariner
Did you mean "feet, inches, pounds..."?
I agree with you on the second part!
-Tom
Old 02-17-2010, 10:07 AM
froudedude froudedude is offline
Rep: 10 Posts: 9
Really, unless we get grammar and punctuation correct, America is done for. Oh, did I end a sustenance with at preposition?
Old 02-26-2010, 05:47 AM
JFdez JFdez is offline
Rep: 10 Posts: 4
weights pontoon
Weight that the pontoon will support=Weight of the pontoon submerged volume at the desired draft- total weight of the pontoon
Old 02-26-2010, 05:54 AM
Rep: 10 Posts: 4
......-total weight of the pontoon (of course, without considering the added weight)
Old 03-03-2010, 11:03 AM
netjaws netjaws is offline
Rep: 22 Posts: 73
cristoph, be careful with using 1/2 pontoon depth as your design draft. beyond the pontoons being 1/2 submerged, your TPI decreases exponentially with each slight weight addition, leading to a very precarious stability situation
Old 04-13-2010, 05:23 AM
conceptia's Avatar
conceptia conceptia is offline
Naval Architect
Rep: 97 Posts: 193
netjaws has made a good point.
Cheers
Aswin
"Aim of any argument or discussion must not be victory, but progress."
Old 04-13-2010, 07:38 AM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1874 Posts: 3,359
Never use a preposition to end a sentence with.
Hoyt
Old 04-13-2010, 11:35 AM
ddrdan ddrdan is offline
Rep: 37 Posts: 66
I received conflicting info on this same topic. How will the pontoon stability fair in the info below?
(used 62#/ft3)
Hull Shape: Square
Pontoon Size (ft): 2.0625'(bottom)* 2.02083' * 14.7' * (2)
Area (ft2): 61.25
Displacement (ft3): 126.3
Max Displacement (#): 7892
Loaded Weight (#): 3420
Volume Displaced (ft3): 53.45
Draft (in): 10.47
Freeboard (in): 13.78
Load Ratio: 42.3%
Safety factor (Base=50% of Max): 7.7% or 620#
Weight balance. Will it ride better with weight in the rear or dead center? clctrader Boat Design 4 01-24-2008 12:12 AM
Perkins 275ti to a BravoIII? WIll the bravo hold? Please help. clctrader Diesel Engines 3 07-03-2007 06:32 PM
fish hold stories awannabe Wooden Boat Building and Restoration 8 06-10-2005 01:32 AM
how well do epoxy rot replacement schemes hold up capatsue Wooden Boat Building and Restoration 4 03-18-2005 05:14 PM
Average Human Weight, Safe Excess Weight, &c. Free Pirate Boat Design 12 03-14-2005 01:40 AM
