Old 07-03-2007, 06:56 PM
Valk's Avatar
Valk Valk is offline
Rep: 10 Posts: 6
How do I calculate displacement from weight?
Is there a way to get a rough idea of what a small craft would displace? Like if a small boat weighs in a 50 lbs and the user weighs 200 lbs, is there a formula to find out about how much water the craft with the user in it would displace?
I would think you could then fill the boat with that much water and see about where it will sit the water, kinda... Makes sense to me Roughly of coarse, Not taking into consideration the thickness of the hull etc.
Old 07-03-2007, 07:27 PM
Hank Rosendal Hank Rosendal is offline
Senior in age only
Rep: 30 Posts: 9
Hi Valk
Filling your boat with water, would give you a figure in liters: the volume of the boat.
You need to find the weight of the boat. A small dinghy you might be able to weigh directly on 2 scales or park the trailer with boat on 2 or 3 scales and weigh the trailer again empty.
If your boat is too big for the scales, nearly all cranes and travel lifts can give you give an indication of weight and then you have a figure of displacement.
For more reading and formulas go to:
http://www.uscgboating.org/safety/bo...ng/subc-4a.htm
Or check this forum:
http://www.physicsforums.com/archive...p/t-33706.html
If you really scientifically inclined go to:
http://www.ceanet.com.au/Products/Ma...FQbIbgodcR4Zpw
Old 07-03-2007, 07:38 PM
SamSam SamSam is offline
Rep: 222 Posts: 1,132
Fresh water weighs apprx. 62# a cubic foot and saltwater apprx. 64#. 4 cubic ft of tapwater would weigh apprx. 248#. Hanks formulas might tell you what water weighs per gallon. 8+# I think. What you say makes sense to me too.
Old 07-03-2007, 07:45 PM
Valk's Avatar
Rep: 10 Posts: 6
Great, thanks for the help gents!
Old 07-04-2007, 06:40 AM
alexlebrit alexlebrit is offline
Rep: 16 Posts: 121
If you can cope with metric it's a lot easier though. I litre of water weighs one kilogram, and is 1000 cubic centimetres. Everything's based on this and it's all tens, hundreds thousands etc, so much much easier to work out.
So in your case 50lb boat + 200lb captain = 250lbs = 113.4 kilograms
So you'll displace 113.4 litres of fresh water
or
29.96 US Gallons.
I think Google will convert these things back and forth from metric to imperial to us if you want though.
Old 07-04-2007, 08:13 AM
Verytricky Verytricky is offline
Large Member
Rep: 27 Posts: 197
Bloody Hell - Imperial is so complicated!!
Discover METRIC. It works....
One litre of water weighs one kilogram....
No math involved.
90kg man with a 25kg boat will displace 115 litres of water....
Old 07-04-2007, 12:07 PM
Frosty Frosty is offline
Rep: 910 Posts: 4,269
The question was 'how do i calculate displacement from weight"
The answer is weight is displacement.
Old 07-04-2007, 01:08 PM
The question in the end was if he could take the water displaced by weight and put it inside the boat to get a rough idea of where the waterline would be. It seems like that would work. Kind of sort of. When I get to thinking about it though, if you actually have the boat to put the water in, why not put the boat in some water, climb in and see exactly where the waterline will be. That would also take into account the distribution of weight and show where the trim will actually be, which putting water in the boat won't.
Imperial measurements. Is that the system that gives you wrench sizes like 19/32 or 27/64?
Old 07-04-2007, 02:00 PM
colinstone colinstone is offline
Rep: 10 Posts: 44
1 ltr of fresh water weighs 1 kg, 1 litre of sea water weighs 1.025 kg. In salt water a boat will displace less, and so have less draft than in fresh.
Old 07-04-2007, 03:24 PM
Trevlyns Trevlyns is offline
Senior Citizen/Member
Rep: 451 Posts: 689
Frosty has it right – weight and displacement is the same animal.
You have the weight of the empty boat. The person or anything else you put into it is the payload. The total weight equals the displacement at that specific moment. It may not necessarily be the maximum or designed displacement. This would be the empty weight plus the maximum payload as determined by the designer and drawn as the Lwl (Length of waterline) – and often referred to as the DWL (Designed waterline). This is the line at which the craft is designed to sit with its maximum payload.
Displacement is determined by the internal volume of the hull (Volume displacement) which is multiplied by the density of the water in which the boat floats. As pointed out already, that’s why there is a slight difference between fresh and salt water.
Trev F – Amateur designer and part-time layabout.
Old 07-04-2007, 03:59 PM
External?
Old 07-04-2007, 04:09 PM
Rep: 451 Posts: 689
Beg your humble pardon, SamSam!
Old 07-05-2007, 08:03 AM
Large Member
Rep: 27 Posts: 197
So you float higher in seawater but your propellors are slightly less efficient....
Old 07-05-2007, 03:20 PM
Yes, well, we can't let these small discrepensies get out of hand to the point where the planets won't align correctly and the resultant misbalance of the universe allows the earth to tip over. It's just too much bother to clean the workshop after such events.
Old 07-08-2007, 03:13 AM
Rep: 451 Posts: 689
Touche!
software to calculate CG gonzo Software 6 05-17-2007 05:06 AM
wet weight vs dry weight of Diesels... spank Boat Design 3 10-20-2006 04:16 AM
Average Human Weight, Safe Excess Weight, &c. Free Pirate Boat Design 12 03-14-2005 02:40 AM
Displacement versus vessel weight TheFisher Boat Design 10 09-17-2004 08:45 AM
Displacement Weight SEAWINGS Sailboats 12 06-17-2004 12:39 PM
