Old 07-02-2011, 09:02 PM
benoz benoz is offline
Help! naca 65 015 calcs needed
Can someone help me!!! I need someone to calculate the length of bulb and section heights to build a keel bulb to naca 65 015 with a weight of 530kg (Volume 47L)
I'm hoping someone has a piece of calculation software to work this all out!!!
Thanks
Ben
Old 07-03-2011, 07:42 AM
conceptia's Avatar
conceptia conceptia is offline
Naval Architect
Rep: 97 Posts: 193
http://www.pdas.com/profiles.html#p65015
You can use this data to do the calculation. I would suggest you do the calculation alone, rather than trusting an unauthenticated software.
Cheers
Aswin
"Aim of any argument or discussion must not be victory, but progress."
Old 07-05-2011, 04:57 PM
abcdefg abcdefg is offline
Rep: 32 Posts: 22
Can do. But will cost. pm me if interested.
Assume you are building it?
Old 07-05-2011, 05:06 PM
CaptBill's Avatar
CaptBill CaptBill is offline
CaptBill
Rep: 64 Posts: 181
I bet there is something in the spreadsheet download area of this forum. My problem is I can't locate the link to get there. I know I saw a 'spreadsheet file' link. Where did I see that?
Abrahams Altar FOUND
See Footage Jerusalem
http://MountoftheLORD.blogspot.com
Old 07-09-2011, 01:09 AM
quequen quequen is offline
Rep: 165 Posts: 113
Attached is your bulb in .fbm (Delftship free) format.
Also a copy in IGES
And here the properties of the bulb (in pure led). By the way, it gives to me 48 liters for 530kg. Lenght is about 1.76mts (I think, please check the files):
Propiedades físicas de NACA65015 ( Part Configuration - Predeterminado )
Sistema de coordenadas de salida: -- predeterminado --
Densidad = 0.01 gramos por milímetro cúbico
Masa = 530345.00 gramos
Volumen = 48213181.97 milímetros^3
Área de superficie = 937971.93 milímetros^2
Centro de masa: ( milímetros )
X = 721.73
Y = 0.00
Z = 0.00
Ejes principales de inercia y momentos principales de inercia: ( gramos * milímetros^2 )
Medido desde el centro de masa.
Ix = (1.00, -0.00, 0.00) Px = 3424388148.69
Iy = (0.00, 1.00, 0.00) Py = 56890017657.47
Iz = (0.00, 0.00, 1.00) Pz = 56890017657.47
Momentos de inercia: ( gramos * milímetros^2 )
(Medido desde el centro de masa y alineado con el sistema de coordenadas resultante)
Lxx = 3424388149.78 Lxy = -241074.48 Lxz = -0.00
Lyx = -241074.48 Lyy = 56890017657.31 Lyz = 0.00
Lzx = -0.00 Lzy = 0.00 Lzz = 56890017656.55
Momentos de inercia: ( gramos * milímetros^2)
Medido desde el sistema de coordenadas de salida.
Ixx = 3424388150.54 Ixy = 216502.23 Ixz = 0.00
Iyx = 216502.23 Iyy = 333142038305.35 Iyz = 0.00
Izx = 0.00 Izy = 0.00 Izz = 333142038305.35
Old 07-09-2011, 02:52 AM
Frosty's Avatar
Frosty Frosty is online now
Rep: 1693 Posts: 5,876
If you cant give a proper name or a location then you will have difficulty with credibility.
Just sayin.
Old 07-10-2011, 06:17 PM
Rep: 32 Posts: 22
Just sayin.
If forum post counts and rep points were a measure of credibility, then I would be screwed, but I live and work in the real world where they don't really mean much to me.
If the opening poster is/was serious about taking things further, then I am certainly in a position to assist. I am not sure that you are in the same position. Just sayin...
Its moot anyway, as at least a half answer has been presented above (kudos to quequen), and the opening poster has not returned it seems.....
Old 07-10-2011, 08:47 PM
Frosty's Avatar
Ha --I never thought about the cred number count, It was credibility needed to encourage payment from some one when you have total anonymity.
(Send money to me my name XYZ and I live over there somewhere).
But I'lle guess your American and you name will be Tod or chuck.
Just sayin.
Old 07-10-2011, 10:21 PM
Rep: 32 Posts: 22
Just sayin.
I think you need a productive hobby. I made an offer to the opening poster that I could assist, after contact via private message.
I have the tools and ability to do a quick job like this, but I do expect to get paid for my work. Why should this be of concern to you?
And my real name is neither Tod nor Chuck and I am not a citizen of the USA. If I were to guess, I would say that you are not native Thai, and your real name is not Frosty. How am I doing here?
Old 07-10-2011, 10:35 PM
Frosty's Avatar
Yeah your doing pretty good there errr Bob. I cant spell your real name its too long on a Qwerty board.
No--its of no concern --well just a little bit.
Just sayin now said.
Buoyancy and Floatation calcs Mr.Design Stability 7 10-02-2011 04:21 PM
beamboy eng. calcs Guest62110524 General Computing 1 01-01-2010 02:06 AM
Iso For Scantling Calcs S Hondros Boat Design 3 04-02-2006 02:12 PM
Edmonds Calcs JEM Wooden Boat Building and Restoration 0 07-22-2004 01:01 PM
Mast size calcs Willallison Sailboats 14 01-09-2003 10:04 PM
