| GZ characteristic curve on a model vessel - Help! HI all, I am working on a project and am required to extract the GZ curve of a model replica of an existing fishing boat The real boat weighs 2600kg, displaces 2.54m^3 water, length 6.7m (salt water - 1025kg/m3) The replica is 1:14 scale - measuring 0.479m. (fresh water - 1000kg/m3) How should I calculate the displacement of the replica? [If you had to divide the mass by 14, it results in 185kg! ... not very realistic I suppose!] Do I need to divide something qubed (^3)? thanks for your feedback steve |
| Weight scale as (scale)^3, area, as (scale)^2 ![]()
__________________ All the stresses in my designs are 95% of permissible. |
| This mean , weight of model have to be 14^3=2774 times less as prototype. 2600/2774=~0.95kg
| Thanks for your prompt reply! Please correct me if I am wrong. weight must be ^3 since as density = mass/volume, and since volume must be also scaled by 14^3, this is directly proportional to mass [ mass (dir. prop) vol.const ] in which case, the constant is the varying density from salt to fresh water. And the reason volume has to be ^3 in the first place, since for a simple 3d shape such as an oblong, as the 3 individual dimensions (L, B, H) must be scaled individually. Hence, for a complex shape - hull form, the volume is scaled in qubed proportion. Awaiting your reply! Thanks steve |
| Yes, volume scales as Scale^3, while density remain the same. And yes, because 3D object has 3 dimensions, and each of them is scaled M times, volume (and consequently, weight) will be scaled M^3 times. It easy to prove mathematically, with 3D Integrals, if there is sufficient familiarity with this sort of mathematics. Or physically, using same 3D shapes of different scale from the same material: modeling clay, wood, lead (easy to cast), or even buckets of similar shape, but different size, filled with water.
| Thanks for your approval Indeed it has to be proved by integration regards steve |
| As a point, you understand that the GZ curve you get from the model will not be the same as the real vessel, but also well be off due to scale effects, it will have ~1/14 the scaled stability of the real vessel (i.e. ~ 1/14^2)?
__________________ A vessel is nothing but a bunch of opinions and compromises held together by the faith of the builders and engineers that they did it correctly. Therefor the only thing a Naval Architect has to sell is his opinion. |
| Because GZ is a linear parameter, (measured in m), it will scale the same as 1/14. Then the only issue left is the accuracy of measurements, as all the errors and inaccuracies will multiply by 14 when recalculated to full size.
| Ok, BM tracks scale, but I seem to recall a scale factor issue as to why scale models are not used for stability.Maybe I need to dig out Bhattacharyya as it might be a dynamic factor as opposed to the static ones.
However, main issue I think is it actually much simpler and cheaper to use calculations.
Of course, for dynamics, like rolling, sea-keeping, maneuvering, all the mass distribution characteristics became important and need to be modeled correctly.
| Hi, actually what I think is of utmost importance, is that the vessel heels about the centre of floatation. Ballast weight will be added as necessary to ensure that the vessel achieves the scaled draught, thus to mimic the same displacement, in a scaled manner. thanks steve |
What is more important, is vertical position of CG. If VCG is off, all the righting levers will be also off. It depend on how much loading conditions you need to explore. If there are only 2-3 load cases, it is more time-efficient to mimic displacement, LCG and VCG accurately for each of them and make series of inclinings for every load case. If there are tens of load cases, it is more efficient to make some series of inclining tests, extract hull form stability parameters from them, and do the rest of work by normal stability calculation routine.
| I would only require 1 load case, that of the vessel and equipment on board. I presume that finding the right position for the vertical centre of gravity is going to be the most time consuming pain in the *** procedure! Any ideas to how this can be done effectively for the model? thanks steve |
| GZ curve | genesis-uno | Stability | 2 | 06-19-2007 08:21 AM |
| Borg Warner Velvet Drive Model 72c Current Model | DAVID HOSEGOOD | Diesel Engines | 1 | 12-27-2006 12:30 AM |
| GZ curve | ivansalasj | Sailboats | 7 | 02-23-2005 12:51 PM |
| Thrust Characteristic | Hamidi | Education | 0 | 08-11-2004 09:20 PM |
| Homogeneous curve | duluthboats | Boat Design | 9 | 04-28-2004 04:44 PM |
