| Sure, do an inclining experiment of the model. Assuming you have it instrumented to give you the angle of heel, this is a simple matter. However, as others have said, for static stability considerations, calculations are a more efficient way to go.
__________________ Henry Reeve, P.E. |
For LCG - just make sure trim is correct For VCG it it is possible to hang model several times , as in picture. Once VCG is correct, make inclining tests, get results, and make them in your thesis, diploma or whatever you do .
__________________ All the stresses in my designs are 95% of permissible. |
| I did extract the result experimentally, .... by heeling the vessel attached to fixed lever about the centre of gravity. This makes sure that the same displacement is kept at all times. The results are satisfactory. Thanks all for your help |
| GZ curve | genesis-uno | Stability | 2 | 06-19-2007 08:21 AM |
| Borg Warner Velvet Drive Model 72c Current Model | DAVID HOSEGOOD | Diesel Engines | 1 | 12-27-2006 12:30 AM |
| GZ curve | ivansalasj | Sailboats | 7 | 02-23-2005 12:51 PM |
| Thrust Characteristic | Hamidi | Education | 0 | 08-11-2004 09:20 PM |
| Homogeneous curve | duluthboats | Boat Design | 9 | 04-28-2004 04:44 PM |
